power windows/locks
Old May 11, 2006 | 11:30 PM
srglynn's Avatar
Lightbulb power windows/locks
does anyone know how hard it is to put power windows/power locks in a 05 xl?would i have to change the door panels?where can i get the parts to do this?
Old May 12, 2006 | 12:14 AM
02SuperCrew4X's Avatar
SEARCH!
This option has been discussed many thousands of times since I have been a member here in Summer 2004. It takes 30 seconds to search the site, and be done. If you can't use the search function, you shouldnt be posting here, IMO.
Old May 12, 2006 | 09:54 AM
suprpntr's Avatar
Originally Posted by 02SuperCrew4X
SEARCH!
Normally I would agree with you. However there have been a number of times I have used the search and come up with nothing. And I do know how to use it.
Old May 12, 2006 | 11:00 AM
TruBluSuperCrew's Avatar
SEARCH!
Give the new guy a break. It takes a little while to figure out how to use the website and get around. I agree using the search option would be best, but you should have gotten around to it better for the newbie.
Old May 12, 2006 | 12:14 PM
ChrisAdams's Avatar
It's an easy job. Huge debates on which window power to use. The switches can be mounted several dozen places. The door panel swap will work but gets expensive. See my classified for a door panel if you want to see what that involves.
Simplest method is what I used. Colibri kit (search under Colibri for lots of hits) with switches mounted flanking the cigar lighter. Spal kits seem to slow on the windows. My Colibri motors move fast enough but I put express up and down on them so I wouldn't notice if they were slow.
Power door locks is a snap. I have installed Crimestopper kits on these trucks, and that can be done in a relaxed Saturday morning. Putting a Ford Dealer installed type in take longer and you need to add relays but still not a major job.
If you decide to do both jobs do them at the same time.
Biggest problem in these trucks is some truck, mostly 4x4, have a white block on the body side of the door jamb wire boot. That is a BEAR to work with. Those of us that just have a simple rubber boot that pulls apart at both ends putting stuff in the doors is a snap.
Search under ‘white block' for those problems.
Keyless remote is one of the essentials to add in my opinion. If you are used to keyless going back to a key is almost impossible.
Chris
Among other mods to my STX;
Ford deluxe Alarm/Keyless.
Tailgate lock hooked to keyless.
‘Trunk lock’ on my front panel of my Folding tonneau cover.
Colibri power windows.
Express up and down Ford modules on the power windows.
Keyless keypad in drivers handle.
Old May 13, 2006 | 12:15 AM
myst's Avatar
Funny, I searched for "power windows" using the advanced features page to constrain the search to only the 2004-2006 forum and came up with the following relevent threads:
This thread
and this thread
and this one
and another
and another
oh look, yet another
and more
yawn
szzzxxxxx
Normally, I would be inclined to agree with you. However the evidence fails to support your assertion. This forum is a rich resource for all things F-150, and with the current model out for 3 model years now, a heck of a lot of routine things have been covered, mostly to death. Additionally, you might try searching on "power locks", in case you don't find what you were looking for in the above list above.
Sorry to be a snot, but your combative attitude was not comensurate with an adequate search effort on your part. Welcome to the forums, there are a lot of very nice people here (including me, usually,) who are very willing to help you accomplish things like this. It doesn't build a lot of confidence in your abilities, however, when you say "I tried" with what appears to be a very feeble attempt.
I would have, except he implied he knew how. Obviously, he either didn't know, or try.
Old May 13, 2006 | 12:33 AM
rocky85's Avatar
This thread
and this thread
and this one
and another
and another
and more
yawn
szzzxxxxx
You have the original poster confused with someone else.
Old May 13, 2006 | 12:37 AM
srglynn's Avatar
power windows
thanks for all the links to the forms,they were very helpful,now I need to get the money together to do this,I am planing to get this done by july.thanks again
Old May 15, 2006 | 11:35 PM
KCAutosound's Avatar
Electric-Life makes a direct bolt in kit for your F150. I have installed quite a few of them.
Old May 16, 2006 | 01:39 AM
ChrisAdams's Avatar
You know the Electric Life product seems to cost a bit more than the factory parts. And it does not include the switches, at least not in any of the ads for the EL.
Any particular reason they would be better than the stock ones?
And what switch setup do you recomend?
I am asking because I seem to get about three e-mails a week on this swap and like to have the best answers possible.
Chris
