Edge vs. TP Xcal2 acceleration times
Old Jan 8, 2006 | 08:07 PM
  #121
RamSS/T's Avatar
Originally Posted by Josiah
I do not see how you got a 7.2 0-60. Look at all my mods, and you beat me with just a tuner, with my XCal2 and the rest of the mods I am running a 7.4 0-60 or so. I STILL can't beat that stupid lowered stock Chevy (flowmaster exhaust only). I have 3.73's as well so I would imagine that would be an advantage over you, I am guessing you are only 200-300lbs less than I am as I am an Screw and you, Scab. I am extremely disappointed in hearing all this.
The weight difference is a little more because his is a 2wd and yours is a 4wd.
Old Jan 8, 2006 | 08:13 PM
  #122
hwm3's Avatar
Originally Posted by pat williamson
Load it and enjoy? BS!! to get the full performance you have to spend much dollars and time to tweak the Xcal 2 (datalogging) I think it might be worth it, but the work is not "already done for you"
I haven't made a single adjustment to the Xcal2 tuning provided to me by TP, and haven't even datalogged yet. That is why I didn't adjust the Edge tunes either.
Old Jan 8, 2006 | 08:14 PM
  #123
hwm3's Avatar
Originally Posted by billindenver
Are all the parameters available to you in the xcal2? So that, provided you had the ability, you could simply adjust the fuel etc yourself instead of waiting for MT to send you the cure? Is it another 6 week wait when you send in the data? Just curious as to how that's done.
Bill
Yes, you can adjust the tunes just as you would with the Edge.
Old Jan 8, 2006 | 08:18 PM
  #124
hwm3's Avatar
You simply can't compare 0-60 times between your trucks and others using different methods of timing. Not to mention the fact that the conditions will make a difference in the times as well. Those types of comparisons prove nothing.
Are you sure the Chevy is stock? Your still probably a few hundred pounds heavier than he is.
Old Jan 8, 2006 | 08:31 PM
  #125
canyonslicker's Avatar
Josiah,
Is that your truck in the sig ? You have got to be kidding.....look at all of the weight with the lift, roll bars, lights, wheels and tires.......oh I almost forgot the racing stripes too....
Dude, your aero-dynamics are just, well... not up to snuff.
No flame intended but there is probably a whole myriad of differences here. It's not a Ford is a Ford type of thing. They are completely different beasts..
Lose some weight (alot), get different gears or go stock tire size, then lose a Chevy.
Just reread the post "LOWERED" stock would indicate not stock. No telling what else isn't.
Old Jan 8, 2006 | 08:40 PM
  #126
inurok's Avatar
Originally Posted by hwm3
OK, I made about 6 runs this morning, 3 with the TP Xcal2 and 3 with the Edge on the Level 3 performance tune. Here's the numbers I got.
TP Xcal2 best:
0-60 6.5 sec
1/4 mile 14.9 @ 93mph
Edge best:
0-60 7.5 sec
1/4 mile 15.7 @ 87 mph
Overall the Edge provides pretty good gains over stock, but on it's highest setting is only as fast as my TP 87 octane tune. If you really want/need the gauges get the Edge, if you want the best performance get the Xcal2.
Wait this chip will let a stock 5.4 3v f150 do 0-60 in 6.5 secs?
Old Jan 9, 2006 | 12:09 AM
  #127
Josiah's Avatar
That is a photoshopped truck I made in my sig, my truck is similar but in stock form
As for weight differences, there have been people claiming of high 6 second 0-60 times and they were 4x4 but supercab. The weight difference is only a couple hundred pounds from my Supercrew. Those couple hundred pounds are not the deciding factor. I agree hwm3, it's probably the timing we are using but it's still a bit off. Regardless, before e-fans, intake and the tuner I would lose by ONLY a car length to the chevy, the improvement from all three mods are pathetic, I am still losing by quite a bit. There was and is no wheelspin off the line from either of us. Take the advertised gains with a grain of salt, in my case I am not much quicker than I apparently was. Must have been a sotp difference. The XCal2 did not provide much of a performance gain in my case, my truck is an early build F150 but I've had no reflash, TP and I are working on datalogs but I'm not sure much else can be done. I do not consider the XCal2 to be my best mod. The only performance gains are the slightly firmer shifts (shifting is not quicker, just knocks you forward a bit when it pops into gear) and the slightly higher RPM shifts. If these are the gains everyone else is so amazed with, I am anything but pleased.
Old Jan 9, 2006 | 09:33 AM
  #128
04NickySP2's Avatar
I love coffee in the mornings
Old Jan 9, 2006 | 10:09 AM
  #129
Thrill Racing's Avatar
Who deleted the information that quoted Troyer's information on RPM's and shift points,etc.
I am not adding to the debate, I will say however that there is simply Troyer Bias on this website. ANYONE with a brain would be able to see that. With that said the company is a sponsor and has given GREAT results to many. I have talked to them and there customer service is some of the best out there.
I will be honest and say I will be using the afore mentioned information to tune my Edge that I received Friday. Also, the above-mentioned sponsorship may be why the information was edited. I personally bought the edge due to the price point with the group buy. I also like the access to the 4 gauges it gives you in a simple, clean, one pod design.
I would imagine Troyer's tuner is better just for the simple fact that the edge has to "INITIALLY" fit all F150's from mile high stadium to New Orleans. Troyer goes to great length to set the tune that matches your driving habits and area of location. Do I think he writes a new tune EVER single time a person orders, I would say no, BUT there is a 6 week wait implying some sort of drawn out process is taking place, ie: every tune is individual.
These are just my worthless 2'c. I would however like someone to put back the information or e-mail it to me because there are literally thousands of troyer posts to look through to find that info and I don't have time.
Thank you if anyone helps me out!!!
Old Jan 9, 2006 | 10:24 AM
  #130
Rochester's Avatar
Wrong thread chief. That info is in the edge peeps thread.
Old Jan 9, 2006 | 10:28 AM
  #131
^^^^^^ Thanks that explains a lot.
Old Jan 9, 2006 | 10:31 AM
  #132
FX4_Guy's Avatar
I remember that post. Troyer himself provided the shift points so I don't think he would have deleted it. I think it is in another thread in Chips and Programming.
Old Jan 9, 2006 | 10:35 AM
  #133
FX4_Guy's Avatar
Here you go. Just needed to look in the chips and programming section.
Clicky Here for the answer
Old Jan 9, 2006 | 12:07 PM
  #134
I did go out and change shift point before I went out to "Lunch". I also changed to 95 octane since I am running 94 Sunoco. Wow, fun times.
Sorry, no "official times" but it is just a lot funner (yes thats a word).
EDIT: My egregious vocabulary is duly noted.
Old Jan 10, 2006 | 11:16 AM
  #135
harborbreeze's Avatar
Angry
Originally Posted by Newt
Troyer's tune is a canned tune. Unless you go through the data logging procedure. I wonder what percentage of Xcal2 purchasers datalog & turn the info in?
The Xcal2 is for ANY FORD from (I think)96 to date. When you purchase one from MT, it has his canned tune in it. The Edge is for 04-06 F-150's ONLY .
Sigh, more misinformation I see.
If troyer provided nothing more than a canned tune, it would not take 14 days to get the programmer from troyer.
The wait is due to the fact that each and every programmer ordered is loaded with custom programs depending on the individual computer code and individual mods.
After datalogging is done and sent to troyer the programs are then readjusted if need be.
There is nothing canned about it, and if you believe that then give Troyer a call instead of believing the nonsense posted here.
