Bye Bye Auto Spring
Originally Posted by ThumperMX113
Im getting the Rancho lift, the kit re-uses the factory coils . . . as well as every other kit unless you get the COMPLETE replacement coil-overs up front.
Originally Posted by -TXF150-
Thumper, I thought you were set on the Fabtech a while back? What made you change your mind?
Honestly, I still wish I could use the Fabtech but I emailed them and they said strictly 5" backspacing. Helo Maxx 6s are 5.5" backspacing and Im not going to sell my wheels and get ones when the Rancho will be more than good enough for me. I was also a little leary about the driveshaft work, I know its not a big deal but thats just me.
was going to let this die but,let me ask,without the spacer at top ,ie no lift,what happens if you jack the truck up by the frame or go airborn?the tires will hang down to the full extension of shock/strut ,will upper a-frame still hit the spring ? my guess is yes.with the spacer you are just moving the control arm closer to the spring more often but still in the same plane of geometric travel as stock...so stock it will hit the spring too just not as often
Originally Posted by mslc1
...without the spacer at top ,ie no lift,what happens if you jack the truck up by the frame or go airborn?the tires will hang down to the full extension of shock/strut ,will upper a-frame still hit the spring ?
with the spacer you are just moving the upper spindle closer to the spring
if it was factory settings, then the spring would be sitting 2" inches higher, farther away from the spindle..... IMO
Oh yeah, i also attempted to contact extremetrucktoys about this problem, and sent the pictures.. NO reply yet...
Originally Posted by OMC
I have the skyjack spacer and don't see what you guys are talking about. I went out and looked at both sides. i even drover up on a curb to see if that made a differnce and still nothing.
Originally Posted by HCFR-Halligan
Red Wing can you post some pics of the truck now with the blocks removed from the rear?
Not happy, after doing some research (apparently not enough) decided to buy the spacers, put them in last night, truck looks perfect for all it is worth. Go to take it on a test drive and hear clunking on a rough road. Thinking I have done something wrong putting it back together I decided to take it to my mechanic to check it out... Will find out tommorow what the verdict is, not going to be happy if I need to be pullin em back out.
Guess its the price you pay to make your truck look correct?
autospring
i have the 2.5 autospring and no problems to date as for the angles cv joints were designed to handle increased angles thats one of the reasons auto manufacturers did away with the old u joint front ends ford is running cv joints on the front of the superduty now also. so stop worrying and enjoy your lifted truck.its a 4x4 and there will be repairs needed from time to time lifted or not.
