Bye Bye Auto Spring
Old Sep 26, 2005 | 10:44 PM
  #106
Big Bad Booty Daddy's Avatar
Thumbs up
garscott Thanks for your post and pics
I barely received my autospring 2.5 this past Friday, I had ordered it just before this thread got started, prior to it everybody was saying how happy they were bla bla bla bla. Oh well. I have to take in my truck to the dealer for an a/c problem and a squeaking noise in the back of the truck when i go over speed bumps. After that ill get it installed and wish for the best.
Gallery:
https://www.f150online.com/galleries....cfm?gnum=6119
Old Sep 27, 2005 | 12:02 AM
  #107
garscott's Avatar
Gallery:
BBBD,
Glad to help. I know you will like it. I'm liking mine more everyday. I think I would have get what some call a real lift before I dropped it back down to stock hieght. I will do that eventually, but for now, the spacers and a few scratches will do.
Good luck.
Gar
Old Sep 27, 2005 | 12:47 AM
  #108
bofer's Avatar
so, is there any company out there right now that will give me a suspension lift that will lift my truck an actual 3 or 4 inches. i know the rancho says 4 but it is really like 5.5, thats to big for me, 3 or 4 real inches would be perfect!
Old Oct 19, 2005 | 12:59 AM
  #109
rocky85's Avatar
I just ordered my Auto Spring 2" front lift kit. Is there an update to this thread?
The current listing for the Auto Spring reads, "This is our new re-designed offset version. It allows for more suspension articulation and gives you complete upper control arm to coil spring clearance."
Has the lift been redesigned since people on this thread purchased their kit?
http://cgi.ebay.com/ebaymotors/2004-...QQcmdZViewItem
Item number: 8008367279
Old Oct 19, 2005 | 04:02 AM
  #110
EDGEonSTEROIDS's Avatar
Somebody else mentioned in another post about a re-design of the autospring kit that fixed the clearance issues. Didn't mention how it was re-designed or intended to work. Unless it makes the top of the shock/coil lean in toward the motor i dont see how it can work. I'm going to e-mail AS right now and try to get some specifics. I'll let you know what i find out.
Edit: E-mail sent...now sit back and wait
Old Oct 20, 2005 | 02:52 AM
  #111
AutoSpring's Avatar
Re-design of our leveling kit.
Over the past few months I have received calls from members of this Forum about the issue of coil spring to control arm rubbing with any leveling kit installed. I,am here now to try and address this issue and give some insight into why some truck owners experience the rubbing and others don't, and what we have found is the cause and our solution.
Just over two years ago we designed and began installing our leveling kits on test vehicles with stock tires and wheels in our local area. No contact with the control arm to coil was seen on our test trucks.
Only recently we learned about the rubbing issue from this forum and some of its members talking about it. We decided to figure out why some trucks rub and others don't. We have replaced numerous factory strut assemblys with Billsteins and threw the stockers in our scrap bin. Just recently we dug em out and cut them apart and found that not all strut shafts are exactly the same length and also the internal rubber dampers are of different thicknesses. We found the shaft lengths to be up to plus or minus 3/4 inch longer. Different manufacturers must be supplying the strut assemblys to Ford or quality isn't job one.
The longer strut shaft and thinner rubber damper allows the suspension to droop farther which is why some trucks have the rubbing issue and most don't. Larger than stock tires and wheels are heavier and also probably compress the rubber internal damper more allowing more downward travel at full suspension off-load. Next time you go to your local Ford dealer. stand back and look at the pretty line of new F-150's. Notice they don't all sit at the same height in the front end. Coils supplied by different manufacturers tempered at different specs = different rates and ride heights for the same exact models and specs.
The paint rubbing off the coil is only a cosmetic issue not a safety one. But we decided to be the first leveling kit manufacturer to address this issue by re-designing our kits. We now offset our kit so that it pulls the coil/strut assembly inward away from the control arm allowing for complete clearance of the coil at full off-load. We tested our new 2-1/2" kit on a 2005 F-150 Fx4 with 34" tires over severe washboard roads and found no rubbing at all
Hopefully this answers all of the questions you've all been asking about this issue. Please feel free to call me at 1-800-345-0431 or e-mail me if you have any other questions.
Best Regards
Kevin
Auto Spring Corp
Boise, Idaho
Old Oct 20, 2005 | 03:42 AM
  #112
SC_05FX4's Avatar
Kevin, thanks for your post! Are your smaller sized kits also re-designed (2" and 1.5" I think)? I am now considering changing out my ez-lift for your re-designed kit.
Old Oct 20, 2005 | 11:12 AM
  #113
AutoSpring's Avatar
Yes, all of our kits are re-designed with the offset (1-1/2", 2" and 2-1/2") I should have included that in my post last night but forgot.
Kevin
Auto Spring Corp
Old Oct 20, 2005 | 04:08 PM
  #114
BigBlackFX4's Avatar
ATTN Kevin @ Autospring.
I purchased my 2" kit from you about 4-6 weeks ago but havent installed it yet. How can I tell if mine is the new design? If not, are you willing to exchange it for the new design? Thanks.
Old Oct 20, 2005 | 04:20 PM
  #115
PiggNFord's Avatar
Fab Tech makes a 4" lift that my local dealer installs on trucks before they sell them. That kit looks nice, and not too agressive. Shoot me an email and I can send you a pic of that set up.
Old Oct 20, 2005 | 05:58 PM
  #116
F150 Duke's Avatar
Kevin,
Great job deciding to come on here and address this issue publically and fast. You saved yourself a lot of business and even added a lot of business. This forum is a very liquid market of potential buyers. I for one will now consider leveling off my F150 for new tires and rims in the spring when the roads no longer have salt on them.
I've preached for a long time that not all of the F150s have the same height in the front, even the same models (05 Lariat vs. 05 Lariat). For example my 05 Lariat is less than 1.5 inches different from the back to the front.
Again, good job addressing the issue proactively before your competition. That is how a company becomes an industry leader.
Thank you,
Duke
Old Oct 20, 2005 | 06:33 PM
  #117
AutoSpring's Avatar
Hey BigBlackFx4,
Call me at 1-800-345-0431 and we can discuss your questions.
Best Regards
Kevin
Old Oct 20, 2005 | 07:55 PM
  #118
Nico's Avatar
Kevin,
It is great and uncommon for a company to stand behind there product and be willing to publically address the issue and do what is within your power to address and fix the issue at hand.
I for one was back and forth on leveling off my truck. Now that I have read your reply I have good faith in your company and will be ordering a 2" soon enough.
Nico
Old Oct 21, 2005 | 12:29 AM
  #119
Exclamation
Just wanted to say that I had bought the 2.5" Autospring old version from Kevin about a month ago and got hit with all the rubbing issues so i hesitated on the installation , I called Kevin on Monday and asked him about his new off set version, he told me to send him the old ones and he would send me the new version, he was totally cool with it, luckily i never installed the first ones. He should be sending my new kit next week, cant wait. Like i said before just wanted to say that Kevin was totally cool with it.
Thanks Kevin
Old Oct 21, 2005 | 02:01 AM
  #120
Hey I was right about moving the coil inwards woohoo.....
All hail the great Kevin You have done the F150 world a great service, if i was closer to Idaho I'd buy you a drink but since I'm in the middle of nowhere you'll have to settle for me finally buying a leveling kit. Thanks again man for clearing everything up.
