Will 35x12.50/18 fit on stock 04 FX4 wheels
The guy at the 4 wheel parts store said they would but i called 2 other tire places and the said it wouldnt fit on the wheel. I also was told that a 35 inch tire wouldnt fit with a 3 inch body lift by the guy at the 4 wheel parts store but everywhere on here i have looked said it will. Can anyone help me with this?
Most tire manufacturers recommend and 8 to 10 inch wide wheel for a 12.50 inch wide tire, but several members have used the oem 7.5 inch wide wheels with no problems. Also, several members have fit 35x12.50's on 4x4's by using the oem wheels and 2 and 2.5 inch leveling kits, so they will fit with a 3 inch body lift on a 4x4. You will have some minor rubbing on the control arms at full steering lock.
They guys at 4wheelparts are just being cautious. THey are telling you they won't fit without rubbing. Even though it is minor rubbing if anything. They just can't tell people they'll fit, or you would have jackazzes coming back and complaining they rub. Like everyone else said, they should fit with minor rubing.
One helpful hint is look at the specs of the tires you will be buying. Some are wider than the 12.5" they say they are. The toyo mt is a great example. The specs on their site place them closer to a 13.5" wide tire than a 12.5"
