tire pressure?
Old May 23, 2008 | 06:30 PM
jumper5236's Avatar
tire pressure?
my tires came set up with 40lbs of pressure, any sugestions on pressures?
Old May 23, 2008 | 06:45 PM
Ought to be OK, I run mine at 42 to 45psi. Your truck look's great!
Old May 24, 2008 | 02:06 PM
wandell's Avatar
I agree. I've always had good luck with 40 psi.
Old May 24, 2008 | 02:33 PM
tcope's Avatar
Yup... search button and door jam sticker on tire pressure.
Old May 24, 2008 | 03:02 PM
kingfish51's Avatar
Door jam sticker in this case is meaningless. It depends upon the load range of the tire. OE could have been a p series tire, in which case the sticker would say 35.
These new tires are basically a load range E tire with a max of 65. 40 is the lowest you would want to go on an empty vehicle. 45 may be better, especially if carrying a load.
Old May 26, 2008 | 10:40 AM
jumper5236's Avatar
Thanks paw paw, by the way are you running custom tunes in your edge evo? thats my next purchase. I have been talking to corey at power hungry performance a little bit tryiny to decide on what to run, I have seen all the Blast's out there on this forum about that, but i just like tom hear people who are actually running the set up, like mine. Thanks, David
Old May 26, 2008 | 10:58 AM
Jumper, I'm just running the canned tune on level 2, all I adjusted for was tire height to correct speedo. Running 87 I still get 16 to 17 mpg on my daily commute.
Old May 26, 2008 | 11:05 AM
Screw-Me-05's Avatar
Hey jump, sweet rig but your sig is huge and some ppl here dont like that so maybe you should adjust your sig a lil before they make it go bye bye. just a FYI
Old May 26, 2008 | 12:38 PM
jumper5236's Avatar
Thanks for the info, will try to shrink it down. It only took me 2 weeks to figure out how to even get pic on here
