Motor swap in progress...4.6L is OUT!!!
Old Feb 24, 2011 | 08:58 PM
  #151
mxr181's Avatar
I pulled some stuff off last night when I was trying to trace those loose connectors so it only runs for a second but it sounds mean!!! Im gonna go back and get everything plugged in and I think it will be about ready!
THANK YOU SOOOOO MUCH JBREW TOYZ and everyone else!
Old Feb 24, 2011 | 09:00 PM
  #152
jbrew's Avatar
Old Feb 24, 2011 | 09:07 PM
  #153
five0merc's Avatar
Glad it's running!!!! But like toyz says videos!! haha
Old Feb 24, 2011 | 09:11 PM
  #154
mxr181's Avatar
gotta get it to stay running first! and I dont know how to post videos either...wow I am sooooooo stoked right now!
Old Feb 24, 2011 | 09:21 PM
  #155
five0merc's Avatar
Easiest way is to put them on youtube. But I bet you are super pumped!! Now to get your long travel on
Old Feb 24, 2011 | 10:43 PM
  #156
coobies5's Avatar
Vids!
Old Feb 25, 2011 | 01:25 AM
  #157
phil6608's Avatar
Good news , congrats.
Now get that tranny shifting.
Phil
Old Feb 25, 2011 | 01:26 AM
  #158
mxr181's Avatar
i went ahead and took a video on my iphone but I have no idea how to post it online...the truck fires right up and if you give it gas it will run (sounds bad ***!), but without throttle it wont, I am missing the line going from the drivers side PCV / vent which I believe runs to the intake (large vacum leak Im assuming), but the airraid intake I have is weird and it moves the lines from up by the throttle body to much closer to the filter so none of the lines I have are matching up. I wish I would have taken more photos of all the routing of all electrical and stuff, I know you guys said its pretty easy but considering all the parts I have (4.6 and 5.4) they are beginning to get a little mixed up and I cant quite remember everything perfectly BUT I think a few hours this weekend I can get it buttoned up, everything routed cleanly and possibly even ready to drive! Thanks again for all the help guys! Oh and the gauges are no longer sweeping either
Old Feb 25, 2011 | 01:53 AM
  #159
five0merc's Avatar
It seems to be working correctly when you have it grounded correctly. haha. Glad it was something simple though.
Old Feb 26, 2011 | 04:34 PM
  #160
mxr181's Avatar
ok so I have all vacum & pcv hoses and everything on and I think its good, but the truck still doesnt want to idle...I have all the sensors on the intake hooked up and the truck runs smoothly (even at 700-800rpms) but it just doesnt want to stay idleing. I do have a check engine light on but I am dumb and forgot to return my old computer to stock so my xcal is locked so I cant read the codes right now. I tried swapping computers but then PATS wasnt happy and it wouldnt read so I think Im going to have swap everything over so I can return it to stock and unlock my tuner and then hopefully I can read codes. In the mean time does anyone happen to know what this sensor is for? It is located over by the Cruise control module and runs into the harness right by the MAF harness but I cannot find the other side for the plug on anything on that side of the engine bay...sounds stupid and maybe Im just looking past something stupid again but Im not seeing it. Other than not idleing right now the truck runs and sounds great! I want to get this figured out so I can move on to the tranny and see if it is going to shift!
Old Feb 26, 2011 | 04:36 PM
  #161
mxr181's Avatar
Old Feb 26, 2011 | 04:47 PM
  #162
Toyz's Avatar
The only 2 pin connectors I know of on that side are the air temp sensor on the intake tract. There is a sensor on the front timing cover, drivers head. Think its a 2 pin Neither of them are near the maf harness though. The maf runs under the oem air filter housing bracket and connects to the harness there. Check around that area for any other unconnected plugs. Otherwise, that DTC may have the answer if you can pull the code.
Old Feb 26, 2011 | 05:54 PM
  #163
mxr181's Avatar
I swapped the cluster, ignition, key, and comp...Pats is happy, the truck even fired with the 4.6 comp BUT my tuner is still not working, it turns on but does not go to any of the menus or anything...just sits there saying SCT blah blah blah
Old Feb 26, 2011 | 06:34 PM
  #164
mxr181's Avatar
went back out and it worked, I returned the old comp back to stock which unlocked the tuner, then swapped the comp / cluster / ignition /etc and fired it. It took a minute to get the CEL but it came back...I have a P1000 which sounds like its not really a problem, and a P1504 so something is up with the IAC...gonna go try to get it figured out!
Old Feb 26, 2011 | 06:40 PM
  #165
five0merc's Avatar
Glad your getting it man. Just make sure take your time with everything.
