Fact or Fiction
Old Oct 6, 2007 | 06:47 PM
  #46
chris1450's Avatar
Originally Posted by jbrew
NO WRONG!
temp? WHAT?
You may get away with tightening by hand - but why ? You have a problem with instructions - Read the side of the filter box - if you can read..
Better watch this poster - What if someone actually believed this kind of sh^t ?
Filter comes lose - they lose their oil - Fry the motor.. I heard of people just hand tightning and getting away with it - IMO - Very stupid thing to do - WHY????
sorry brew.. hand tight only. There is no reason to tighten more. I never have in 30+ years... and never will use a wrench on a filter. And I have never had an oil leak from the filter.. even fram filters.
Old Oct 6, 2007 | 06:48 PM
  #47
chris1450's Avatar
Originally Posted by worland
Considering the location of the oil filter on the 4.6L & 5.4L enignes, I don't see how it couldn't be full of oil when you start the engine. When I do an oil change, I drain the oil from the pan first. When I remove the filter (doesn't matter which brand I use), it's full of oil.
Of course, I don't buy into the Fram bashing. Been using them for 20+ years and have engines with well over 250,000 miles on them. No problems.
Considering my Dad has an S-10 with nearly 1,000,000 miles on it, and he had the oil changed at a Penzoil joint the entire life of the truck... with their $1 generic filter... I think you guys worry too much about oil filters!
but how many engines and trannies in 1,000,000 miles? Total bs if you ask me. An s-10 isn't capable of that many miles unless you replacet the whole vehicle every couple of years.
Old Oct 6, 2007 | 06:51 PM
  #48
chris1450's Avatar
Originally Posted by chug4real
Why not Fram? I've used them for over 75000 miles and no problems. I use the Fram (tough gaurd). Another oil change is due this weekend so since its a hot topic why not use the fram oil filter other than it just sucks. Give some insight to why. I will switch just as soon as i know what the deal is.
Because if you do a search the surface area of the filter media of a fram is about half the area of a quality filter. that can't be anything but good. And the drainback valve as has been mentioned. For less money I can buy a motorcraft filter.. why would I spend more on fram when it has less desirable features?
Old Oct 6, 2007 | 07:16 PM
  #49
mike8333's Avatar
Zep...did the the problem start after the oil change?
Old Oct 7, 2007 | 01:05 AM
  #50
Zepplin27's Avatar
no
Don't remember exactly to be honest when it started! But for personal experience now the filter that i put back on my truck was a WIX which has a anti drain back system inside that seems to help stop the problem I was hearing!! Before, the place where my girlfriend took my truck to get the oil change put the STP filter on my truck.. Lesson learn "Don't let a women to a mans job". Thanks guys for the insight
Old Oct 7, 2007 | 04:47 AM
  #51
STP filters are also crap.
Old Oct 8, 2007 | 12:04 AM
  #52
02XLT4X4's Avatar
Originally Posted by glc
I've never used a wrench to TIGHTEN an oil filter - and I've been doing this **** for over 40 years. HAND tighten only, as snug as you can get it with your bare hands. Oil the gasket and clean the mating surface with a rag.
Chill out, Jim.......I think you may be the one that's misinformed in this case.
x2, I have been driving for 7 years and only get them hand tight and I haven't had a problem related to the oil filter not sealing.
Old Oct 9, 2007 | 02:50 AM
  #53
jbrew's Avatar
Well , I looked it up. I must have been taught wrong at some point in life - I always spun a new filter on and then put a wrench on the filter for the final 3/4 turn. Prolly been doing it that way 15 years..
I looked at the CAT filters, Motocraft Filters and JohnDeere Fliters that are still in the boxes in the shop - Theres picture illustrations on the filters themselves. That really don't explain it.
On the filter boxes , theres a little paragraph on one of the fold-downs directing you the manufacturers manual for instructions to change.
Well , I went to the mauals - - - Hand tighten new filters in place.
Didn't hurt anything , but pride maybe - Oh well..
I don't think I have ever looked up how to change the oil before - didn't feel the need - but your right - my bad..
Old Oct 9, 2007 | 12:01 PM
  #54
3/4 turn? OUCH! You must be the guy putting the filters on at the factory!
If you DO use a wrench, because the filter is in a hard to get to place and you can't get any leverage with your hands, you spin it on till it makes contact then go 1/4 turn with a wrench.
Old Oct 9, 2007 | 12:45 PM
  #55
jbrew's Avatar
The filter in this 5.4 is the easiest filter I have to change - Don't even have to get on the ground for this one - right there in the fender well. Plenty of leverage. The 4.2 isn't as easy - but not bad. Cats a 4 cylinder generator - John Deere's a lawn tractor, there not bad either..
I'll hand tighten from now on - makes the job easier ..
They'll prolly leak now Kidding...
Old Oct 9, 2007 | 12:48 PM
  #56
Ilovemyford's Avatar
Maybe not 3/4 if that is too tight. But after you hand-tighten the new filter. You should use a wrench for the final 1/2 turn (minimum wrench turn). I don't care how many years you have doing your oil change. It only means you have not properly installed your oil filter for all those years. There is a Technical Service Bulletin 99-3R1 written in 8 languages on how to do it right for a reason. If you want to second-guess the filter manufacturers council, be my guest.
Old Oct 9, 2007 | 01:07 PM
  #57
Norm's Avatar
TSBs are written by Ford. Who the heck is the Filter Manufacturers Council?
Old Oct 9, 2007 | 01:08 PM
  #58
jbrew's Avatar
I looked all over for something to say- use a wrench for the finale turn darnet!! wasnt as lucky I guess . I have all the oil TSB's .. I'm not going to look further because both ways will work. I like the hand tighten way though.
I'll split the difference and wrench 1/4 turn
Old Oct 9, 2007 | 01:10 PM
  #59
jbrew's Avatar
Good Question
Old Oct 9, 2007 | 01:11 PM
  #60
