Project GO FAST is now in progress!!!
Old Apr 14, 2008 | 01:50 AM
  #1411
Klitch's Avatar
hm, like i said, its just an idea that i put out for thought. it'd be nice if he could catch it with a diagnostic tool. see if the injectors are being fired as a batch when it does this.
Old Apr 14, 2008 | 08:29 AM
  #1412
built54's Avatar
the new fuel filter and cam sensor was 45 shipped...
Old Apr 14, 2008 | 09:28 AM
  #1413
jbrew's Avatar
Batch milking the cylinders... I can see where that would cause problems in a few areas if that's the case - progressive problems during the drivecycle that could be adding up to the issue's he's having. Makes sense, you might be right Blitch().
Yea , that's kinduh messed up . I never heard of a bad cam sensor throwing a code.
Old Apr 14, 2008 | 09:35 AM
  #1414
jbrew's Avatar
That's not a bad price IMO - I hope that does it. That sucks , sometimes you can't get away from throwing parts at it - just to see if that's the problem. If it's not , at least you'll have an extra sensor on hand. That can be handy - been there done that.
Old Apr 14, 2008 | 09:45 AM
  #1415
JMC's Avatar
JMC
25 Year Member
If you can data log set it up to log the Cam, crank, injector pulse width, MAF and IAT, RPM, road speed, Commanded rpm, and TP angle and EGR. Next time it dies look at the log to see what it was doing. If one of the sensors dropped you will see it.
Regards
Jean Marc Chartier
Old Apr 14, 2008 | 11:01 PM
  #1416
built54's Avatar
ok so I checked all the wiring to the crank and cam sensor, everything is fine, i cleaned both sensors, and the wiring going to the crank sensor has a stainless wire, looks to be for a ground or something, going around the 2 wires that plug into the crank sensor. the wiring that is wrapping around it is broke loose on the end that plugs to the sensor... but i see no where that it would even go? that bolt isnt loose either>
Old Apr 14, 2008 | 11:18 PM
  #1417
JMC's Avatar
JMC
25 Year Member
The Crank sensor only has two wires that plug into it. The other wire you are referring to is the shield. It should have continuity to ground. It also shares the PCM case ground at splice 101.
Regards
Jean Marc Chartier
Old Apr 14, 2008 | 11:50 PM
  #1418
Faster150's Avatar
Regards
Jean Marc Chartier
without the shield working properly u can get all sorts of interference from the alternator. coils and other items that put off large amounts of EMI. all else fails wrap it up in some aluminum tape used for duct work. or just run another shield wire. i had hell when my shield wire cam unplugged from my coil packs. damn even fuzzed in my stereo.
Old Apr 20, 2008 | 10:46 PM
  #1419
built54's Avatar
well its running great now! New fuel filter and cam sensor. sounds ok dont ya think?
Old Apr 20, 2008 | 10:56 PM
  #1420
jbrew's Avatar
Uhmm, Yea..
Old Apr 20, 2008 | 11:12 PM
  #1421
Klitch's Avatar
i'll let u know when mine will do that
let us know if that new cam sensor did anything as far as the cutout issue.
Old Apr 20, 2008 | 11:14 PM
  #1422
built54's Avatar
it hasnt done it since. that had to be the problem.
Old Apr 20, 2008 | 11:18 PM
  #1423
Klitch's Avatar
well thats cool, makes me feel good for bringing that one up. how long has it been since u installed the sensor?
Old Apr 20, 2008 | 11:20 PM
  #1424
built54's Avatar
about a tank of gas, 10 WOT runs
Old Apr 20, 2008 | 11:23 PM
  #1425
Klitch's Avatar
it was rather persistant before i take it? cool, notch 1 for me lol.
