Project GO FAST is now in progress!!!
Old Apr 12, 2008 | 04:43 PM
  #1396
built54's Avatar
i've never ran a returnless fuel system, its the stock return system. My wideband stays normal, i dont loose fuel pressure, no codes, no signs of anything.
Old Apr 12, 2008 | 04:47 PM
  #1397
Klitch's Avatar
these motors fire injectors off the cam position sens right?
Old Apr 12, 2008 | 04:49 PM
  #1398
built54's Avatar
I do believe.
Old Apr 12, 2008 | 04:52 PM
  #1399
Klitch's Avatar
think there may be a possibility it was sending a signal the pcm couldnt interpret? i know its kinda a long shot but maybe? i know i've had that problem with a different vehicle
Old Apr 12, 2008 | 05:00 PM
  #1400
built54's Avatar
worth a try, might as well replace it. dunno where else to look
Old Apr 12, 2008 | 05:06 PM
  #1401
Klitch's Avatar
well the only other option is crank sens, that would cause you to not fire at all. if the cam position sens is setup the same way as i've learned it, it will fire and run the injectors as a "batch". causing low mpg, slightly less performance. it would also take more time to fire off with the cam position sensor sending a f'd signal too.
Old Apr 13, 2008 | 01:25 PM
  #1402
built54's Avatar
this is really aggravating! went to see a movie last night, and when we got back in my truck it started up just fine, put it in reverse, waiting for cars to move, its at idle, doing just fine then it just dies. i try to start it, it just cranks and cranks no hit. i let off and try again, nothing, try again and it starts up as if nothing happened! then at 2 stop lights just sitting there in drive at idle, rpms go to about 150-200 and then it picks right back up and idles just fine!
Old Apr 13, 2008 | 01:36 PM
  #1403
ONELOWF's Avatar
^^^^^ This sounds like the typical no start to me. I just hold the pedal to the floor on the second crank, and it fires right up. It seems to be in 130*? ect range. This can be tuned out, but it is very much a trial and error fix.
Old Apr 13, 2008 | 01:38 PM
  #1404
97f150kid's Avatar
My truck has done that to me a few different times, never died though, but every time it does it, the RPMS drop to that range, truck shutters like a SOB, and then it just picks back up like nothing happens
Old Apr 13, 2008 | 01:52 PM
  #1405
built54's Avatar
130* ect range?
Old Apr 13, 2008 | 07:53 PM
  #1406
Faster150's Avatar
sounds like cam position sensor to me.
Old Apr 13, 2008 | 09:49 PM
  #1407
Klitch's Avatar
well i didnt wanna hear it from you... but i already had that opinion, and that means another person suspects it.
check the wiring from the cam pos, that was a partial issue on my other vehicle. my only problem with that theory is it SHOULD NOT shut the engine off from what i understand.
Old Apr 13, 2008 | 10:10 PM
  #1408
built54's Avatar
hmm.... leavin my g/fs house today, it wouldnt start... took about a minute. pos. I ordered a new cam sensor and fuel filter from rockauto... im not driving it all week so who cars
Old Apr 14, 2008 | 12:57 AM
  #1409
Klitch's Avatar
how much is the cam sens? i mean we're all shootin out ideas with our reasoning, i'd hate to see you buy something that didnt help.
Old Apr 14, 2008 | 01:47 AM
  #1410
jbrew's Avatar
I seen those pretty cheap over @ Global Auto. They usually carry the factory stuff without the markings.
