Project GO FAST is now in progress!!!
Originally Posted by built54
yea a cold start is 100% normal, i can rev it and it never tries to die
so it only has this idle surge problem when its cold? almost sounds like u got a cracked line or gaskets somewhere and the crack doesnt open up till the material gets hot and expands.
ohh and it is normal for the TPS to move around at idle
someone help me here. I have been having an issue with it dieing after I rev it, I checked my tps voltage with the ignition, .99 ... I Start the truck, and at idle, the voltage jumps around from 1.02-1.32 constantly.... is that normal??
As suggested, recheck 5v source and ground again.
Huh, Your running your rear O2's right? Are those new - Since the new motor? If so, I believe their wired the same. You ever try swapping them with the fronts?
If that was even the problem. I kind of doubt it now that I think about it. If they were bad enough to effect warm idle like that , seems like you would have a set fault and produced a MIL...
Oh well, Glad it worked out .
All three trucks I've done the swap on do this... But only when cold!!!!! I've been trying to pin point it but just haven't had time. According to my A/F monitor, the motor goes lean/rich etc.. other than that, I don't know... yet
I just paid attention to the boost gauge and the tach. Every time your rpm dropped the boost gage would show no vacuum. You have a leak. it could be caused by the IAC sticking or a hose or fitting that is loose and or cracked. A MAF engine responds to a vacuum leak by stalling or by the idle dropping. Have you looked at the EGR valve lately? A small leak will certainly screw up the idle.
JMC
JMC
JMC
JMC
I would think the boost gage nearing zero is a resultant of the motor almost stalling (no spinning) therefore creating no vacum....... I'll have to crank mine up and see if my boost gage does the same thing. I should also say that it'll do something similar if I quickly put it in D after a cold start and start down the road, it'll fall on it's face, then wake up and be fine. There is a gremlin or tuning issue somewhere, but for me only on cold starts.
