Project GO FAST is now in progress!!!
Old Oct 29, 2009 | 09:18 PM
  #2461
built54's Avatar
o2's are both switching at the same rate during this
here is normal acceleration, without surging, stft's... completely different
Old Oct 29, 2009 | 09:24 PM
  #2462
torkum's Avatar
Your O2s should be showing full rich at WOT.
Old Oct 29, 2009 | 09:25 PM
  #2463
built54's Avatar
I know... these logs are at part throttle
Old Oct 29, 2009 | 09:52 PM
  #2464
torkum's Avatar
Might be time to get back on the dyno with your tuner
Old Oct 29, 2009 | 09:56 PM
  #2465
jbrew's Avatar
Did you ever see what Justin posted about the OEM Bosch sensors ? I think ONELOWF posted this once. Anyway, there's a graph here comparing Motorcraft to Bosch and problems Bosch sensors have, not sure it will help, but take a look.
http://www.vmptuning.com/forum/showthread.php?t=825
Old Oct 29, 2009 | 10:20 PM
  #2466
built54's Avatar
I am my tuner... I can do everything on the street as I can on the dyno, but that would be pointless because the ONLY thing that is different in data logging is the STFT.
Old Oct 29, 2009 | 10:22 PM
  #2467
f150fella08's Avatar
ok..i thought the best thing to do was go back with bosch 02's i think someone on here told me that when i decided to change mine,
Old Oct 29, 2009 | 10:23 PM
  #2468
built54's Avatar
Good reading... I am using motorcraft o2's...
Old Oct 30, 2009 | 08:06 AM
  #2469
ONELOWF's Avatar
You might try to force open loop and see what happens. More info without the O2s in the game.
(ECT_for_open_Loop - set to all zeros)
6% variation between stfts is too much....3-4% with aftermarket cams is the outer limit??
Old Oct 31, 2009 | 11:18 AM
  #2470
Veteran: Army
there's a live link 5.1.0?????
Old Oct 31, 2009 | 01:18 PM
  #2471
built54's Avatar
Ive been using it for a while
Old Oct 31, 2009 | 01:19 PM
  #2472
built54's Avatar
I will try that
Old Oct 31, 2009 | 01:32 PM
  #2473
built54's Avatar
This is all I have under open loop... dont see ECT_for_open_loop
Old Oct 31, 2009 | 01:36 PM
  #2474
Klitch's Avatar
keep at er joey, you and one low f are teaching me more lol
i think part of my problem may be my bosch o2's then, they flag rich intermittently, and the thread you showed me makes me question them more.
so how easy is SCT Adv. 3 to use?
btw, whats the "fuel open loop TP"? could that be what your looking for?
Old Oct 31, 2009 | 04:45 PM
  #2475
Veteran: Army
I thought I had the latest version, thanks, I'm downloading 5.1.0 right now
