Project GO FAST is now in progress!!!
Old Oct 28, 2009 | 07:07 PM
  #2446
Matts ford's Avatar
Originally Posted by ONELOWF
Sorry, my mistake. It is a members only forum and built54 can get on there.
alright makes sense.
Old Oct 29, 2009 | 08:35 AM
  #2447
built54's Avatar
I actually logged in, and it wont let me view it still. can you copy and past it here?
Old Oct 29, 2009 | 10:33 AM
  #2448
ONELOWF's Avatar
Here are two sections that I thought might be helpful, if only as something to think about..........
Another area to help finer level fuel control is the load with failed MAF table which is a table used by eec when "guessing" what the engine needs for transient fuel (or situations where you go from little throttle to full throttle or other transient driving situations).
Once the egr is switched off it doesn't matter, right?....it just caught my eye.
....did you lower the EGR flow to zero below 3500? The lower EGR flow will help with idle and have a significant impact on low rpm bucking off idle.
Old Oct 29, 2009 | 11:12 AM
  #2449
JMC's Avatar
JMC
25 Year Member
Can you datalog TPS values vs RPM? If the TPS is fluctuation at WOT it could cause surge. I would also look at the inferred Barometric values. They should correspond to your area. Local Airport would be source of base numbers.
Old Oct 29, 2009 | 03:46 PM
  #2450
ONELOWF's Avatar
The min and max barros are usually set at 27 for a boosted app which effectively zeros them out so they will not learn over time and adjust fuel. The maf will take care of 99% of atmospheric changes.
Old Oct 29, 2009 | 07:34 PM
  #2451
built54's Avatar
yeah my bara sensor is deleted... egr is deleted, all values in tune are adjusted for this. TPS stays the same when its surging.
Old Oct 29, 2009 | 07:49 PM
  #2452
built54's Avatar
I found something in my data logging, stft's are weird during surging. How do I put a copy of my screen on here? I can only save it as a word document and cant upload it here
Old Oct 29, 2009 | 07:52 PM
  #2453
built54's Avatar
http://www.nloc.net/vbforum/attachme...rging-doc7.doc
Old Oct 29, 2009 | 08:14 PM
  #2454
torkum's Avatar
Hey Joey, if your not a member a nloc you can't view.
Old Oct 29, 2009 | 08:15 PM
  #2455
jbrew's Avatar
You can post it here Joey ~ Open your Word Doc/Hit the "PrtScn" (print screen) key on your key board/Open the "Paint" Program/file/paste. Then "save as" to your desktop and upload from their.
It's converted to jpeg when you hit "PrtScn".
Old Oct 29, 2009 | 08:26 PM
  #2456
built54's Avatar
It does this ONLY when surging
Old Oct 29, 2009 | 08:35 PM
  #2457
torkum's Avatar
Is your LTFT about the same? STFT changes everytime your start the engine.
I know its not checked but is the MAF AD correct? Seems very high.
Old Oct 29, 2009 | 08:42 PM
  #2458
built54's Avatar
ltft is flatlined during this
Old Oct 29, 2009 | 08:52 PM
  #2459
built54's Avatar
MAF counts are normally rising as I accelerate, I've NEVER seen my STFT's do this, And I have well over 200 data logs.
Old Oct 29, 2009 | 09:10 PM
  #2460
ONELOWF's Avatar
Could the o2 on the bank 2 be shot? It looks lazy, as if it hesitates at top and bottom of the graph and does not switch cleanly.
