Project GO FAST is now in progress!!!
Old Sep 28, 2008 | 02:17 PM
  #1771
built54's Avatar
Yeah, my buds cummins which has over 1200ftlbs runs even with me
Old Sep 28, 2008 | 04:11 PM
  #1772
jbrew's Avatar
Fun stuff!! Hey what does that Camaro run at the strip?
Old Sep 28, 2008 | 04:17 PM
  #1773
built54's Avatar
He has never been to the track, I wish i knew tho
Old Sep 28, 2008 | 07:20 PM
  #1774
jbrew's Avatar
Well, I can't wait until you run yours - been waiting for those numbers. I'm thinking 11's. You have some idea yet?
Old Sep 28, 2008 | 07:50 PM
  #1775
Blown F-150's Avatar
Well I would be pretty damn proud if the only truck I ran against that was even had in that kinda power!
I would really like to see what you'd run in the 1/4, although you may only be able to run once before they tell you that you need a cage!
Old Sep 28, 2008 | 08:47 PM
  #1776
ONELOWF's Avatar
Yep, it warms my heart to see you giving the cars a good race....fine truck!
Old Sep 29, 2008 | 12:24 AM
  #1777
built54's Avatar
haha thanks guys... I cant wait to get some new dyno numbers too
Old Oct 16, 2008 | 06:46 PM
  #1778
What fuse do you keep blowing? I'll pull the wiring diagram
Old Oct 16, 2008 | 06:51 PM
  #1779
built54's Avatar
the pcm fuse. its done it 8 times now, mostly only when I hit a big bump. there is no obvious loose wire, or bare wire touching anything it shouldnt....
Old Oct 16, 2008 | 06:55 PM
  #1780
Matts ford's Avatar
just take a break and join us in the pie thread
https://www.f150online.com/forums/en...ord-sucks.html
Old Oct 16, 2008 | 07:04 PM
  #1781
Matts ford's Avatar
did you make sure the plug to the pcm is good and tight. i'd also like to see some videos
Old Oct 16, 2008 | 07:08 PM
  #1782
boss1984's Avatar
breakno breakhe has to figure out the problem and fix it to meet us in SoCo for a good evening of racing..then u can enjoy some
Old Oct 16, 2008 | 07:26 PM
  #1783
This my sound wierd, But does the PCM smell burnt, you know that electronic burnt smell when a resistor blows. I am curious if it is in the PCM itself. I have never pulled one apart , but I don't think the boards are sealed in silicone or anything.
I had a pinched wire in the loom that goes over the engine against the top-back of the firewall, but I'm not sure if the power supply comes from under the dash directly from the fuse panel. I will have a look.
Old Oct 16, 2008 | 07:31 PM
  #1784
built54's Avatar
PROBLEM SOLVED! seconds before heading to the scrap yard my intercooler pump wire was touching a ground, i thought hmm... no way. so i started it up, touched that wire to ground, and pop goes the fuse. I fixed the wire, and problem solved! Ill cya tomorrow night boss!
Old Oct 16, 2008 | 07:35 PM
  #1785
