Project GO FAST is now in progress!!!
Old Oct 10, 2007 | 05:58 PM
  #271
Klitch's Avatar
Originally Posted by Faster150
damn! lol thats alot to bore.. i think u mean .030
lol my bad i missed a 0 but yeah you get the jist.
Old Oct 10, 2007 | 06:59 PM
  #272
Faster150's Avatar
Originally Posted by Norm
Piston slap would be at the bottom of the cylinder not top. Not sure what would cause that damage. Failed ring?
yeh i was thikning that to ring seized in bore and cause it to score the sides of the bore. i was wondering which one it was if i remember correctly number 4 runs the hottest unless he did the coolant mod. unless he spun the motor up high enough to float the piston. that would cause the piston to rub up top instead of the bottom. i guess he picked a good time for the new motor! im wondering what minds gonna look like once i pull it appart
Old Oct 10, 2007 | 10:25 PM
  #273
built54's Avatar
Well damn. I got the tank today. Got it all plummed, after breaking 2 drill bits, and bending 4 to get 2 holes in the bed for the water lines. Turns out my pump is F'ed. It does not pump. Damn
Old Oct 11, 2007 | 12:29 AM
  #274
SlammaJamma's Avatar
Damn man...one bad thing after another eh?
Old Oct 11, 2007 | 02:41 AM
  #275
jbrew's Avatar
DANG Joey - these are between 40 - 50 bucks - Little suckers sharpen up to 1/2 in 5 seconds - Wouldn't be without one now - The Mechanic at work use to carry one of these on the service truck .. Nothing like needin a bit when everyone's closed, to far away - or, you just don't feel like going anywhere..- that sucks..
Old Oct 11, 2007 | 08:23 AM
  #276
built54's Avatar
yeah i would have sharpened them but they broke all the way down by the chuck...
Old Oct 11, 2007 | 01:48 PM
  #277
Klitch's Avatar
your pump was used?
Old Oct 11, 2007 | 08:14 PM
  #278
built54's Avatar
Yeah I was told it worked. I just got a deal on a good pump, not an L pump.
Old Oct 11, 2007 | 08:54 PM
  #279
PSS-Mag's Avatar
From: Lost some where in the middle of the Ozark Mountains!
You dont need the shank, chuck it back up and keep using it.
The only unusaeable bits are bent ones.
Another thing I do with broken bits is take them to the bench grinder and sharpen the opposite ends to use tham as make shift EZ-outs.
Old Oct 11, 2007 | 09:36 PM
  #280
Klitch's Avatar
i got my pump off e-bay, came in a ford motorsports box brand new.
Old Oct 11, 2007 | 09:49 PM
  #281
Faster150's Avatar
u should be able to go to harbor freight tool company or possibly granger if they got those up there and get a pump.
Old Oct 11, 2007 | 11:03 PM
  #282
built54's Avatar
well I got my pump working. Flowing the water just fine, put 4 gallons in it, hooked up my laptop in hope of it working, got on the road, and I have 100% power. I data logged it and got to a stop light, gave it almost half, and it just lit the tires up all the way untill it hit 2nd, and this was at ALMOST 1/2... Im going to send the data logging to my tuner to make sure it all looks ok b4 I go WOT, but I can not even tell you how amazing the power is. I just have a bad feeling about my tranny. Videos will be taken tomorrow
Oh, and my IAT2 didnt get over 110 running it like that!
Old Oct 11, 2007 | 11:04 PM
  #283
built54's Avatar
I Do because my hole saw is too deep, bit isnt long enough, oh well who cares, i got it fixed
Old Oct 11, 2007 | 11:22 PM
  #284
Tumba's Avatar
how are you?
i save on the bits by drilling real slow and putting lube on the bit
learned from that a machinest saves alot of drills
Old Oct 11, 2007 | 11:25 PM
  #285
built54's Avatar
Originally Posted by Tumba
how are you?
Yeah, its different with a hole saw, it catches and snaps or bends the bit. Anyway, enough on drill bits.
