THE H.P FREAK'S "SUPER FREAK" 5.4 BUILD UP!! (pics)
Old May 16, 2006 | 01:48 PM
  #676
Neal's Avatar
Originally Posted by 02SUPRCRUE
Hey Neal. Why did you add the friction modifier...the Royal Purple I used (75W140) stated it had modifier in it already. Just curious and wondering if I need to add it now. BTW GREAT POST I need more disposable income like you so I can add more mods.
HI!... Over the years I have learned to never trust the so called friction modifier that company's say they add to their differential oils. I've had failures in the past. So I always add the FORD friction modifier when ever I do a diff oil change. Never had a problem since I've been doing that and find that the clutches grab quicker and last longer.
Old May 16, 2006 | 03:15 PM
  #677
raider's Avatar
well since I have probably sold more Moog and Ford parts then most ppl here I will chime in on this
Yes Ford OEM parts dont come with zerks but that doesnt make them crap parts...I have had Moog parts fail faster then OEM parts and have done more parts replacement on the aftermarket parts then the OEM parts...if you have good luck with one brand thats great...and just like many have had great success with the OEM parts also
Old May 16, 2006 | 04:19 PM
  #678
Neal's Avatar
HI!... Well IMO the stupidest thing FORDs ever did was starting to use zerkless suspension/steering components. The F-150 components fail all the time. Always reading about where some ball joint let go or a tir rod end snapped. The only reason mine have lasted almost 7 years is because I grease them through the boots with a needle attachment for my greae gun and I run synthetic grease. I do notice that 4X4 trucks seem to wear the parts out fast due to lifts, larger tires, off-roading, mud, dirt, sand, etc..... I think if FORD would re-install the grease fittings back into their suspension/steering parts that they would last much longer. If you actually look at the stock FORD parts vs. the MOOG parts you will notice that 90% of the time they are identical except for the addition of grease zerks. They even look like they were forged in the same mold, same casting marks. The other 10% is usually thicker and better built. The grease fittings make a world of difference. Too bad FORD doesn't realize this. Mabey after a few more people get killed and some more lawsuits they will learn.
Old May 16, 2006 | 07:56 PM
  #679
Wild Bill's Avatar
When I had my '94 F150 and the ball joints went out, I replaced them with aftermarket ones that had grease zerks.
Old May 17, 2006 | 02:53 AM
  #680
Faster150's Avatar
hehe my truck still has the zerks
Old May 17, 2006 | 03:24 PM
  #681
Neal's Avatar
HI!... Yes but you only have 3 zerks where there should be around 10.
Old May 30, 2006 | 10:16 PM
  #682
Neal's Avatar
HI!... Well I've got all 4 new "L" rims om and with the NITTO rubber. The GMS COPS came in. I'll be picking them up on SAT. Then I'll be ordering the 3 AUTO METER gauges to fill the triple gauge pod I had grafted into my upper dash top. Then off to the dyno to do some serious data logging with my N/A 94 octane and my N/A 100 octane race program. Will probably be renting the dyno for a 1/2 to 3/4 day. I guess it's good that the owner is a good buddy! LOL!
Old May 30, 2006 | 11:12 PM
  #683
mrainey889's Avatar
So what's the word on the turbo/turbos. I think I remember reading earlier (months ago) that your cam grinds were intended for a turbo application. Inquiring minds want to know...
Old May 31, 2006 | 10:02 PM
  #684
Neal's Avatar
HI!... Well with all the problems this year with the truck and other things around the house the single T-76 turbo set-up will be pushed back until next spring I believe.
Old Jun 9, 2006 | 04:33 PM
  #685
Klitch's Avatar
lucky you. i just redid my whole front end with new stuff with zerks. talk about an ordeal
Old Jun 23, 2006 | 03:57 PM
  #686
B-Man's Avatar
Neal -
Did you get to do your dyno tuning ?
Everything still working good ?
Just curious - been following this thread for a while now...
Old Jun 23, 2006 | 05:37 PM
  #687
Neal's Avatar
HI!... No dyno tune yet. Ran into major problems with the GMS cops. Just ordered my 3 gauges for the custom dash gauge pod, and a TA PERFORMANCE aluminum 9.75 girdle. Last weekens at the local S/R's I cleaned house 4-0. 1st time running my 100 octane "KILL" program and VP MS-109 racing fuel.
Old Jun 24, 2006 | 01:42 PM
  #688
Faster150's Avatar
what times is the truck runnin now? 1/4 mile ets?
Old Jun 25, 2006 | 04:03 AM
  #689
Neal's Avatar
HI!... Don't know. I'm not planning on going to the track until my truck is dyno tuned. Just have no time lately due to work. I did go to the local S/R's tonight and beat a buddy of mine that has a MUSTANG GT, 5 SPEED that went 13.8E.T at the track. I won by 4 truck lengths. I figure the truck currently runs about a 13.4 - 13.6E.T but that of coarse is just a rough guess. Right now I'm 5-0 at the S/R's.
Old Jul 8, 2006 | 05:37 AM
  #690
Patrick@hmsga's Avatar
I had a friend who had a really nice '02 F150, with a tired 5.4.
He found a complete L motor (with harness, PCM, L computer) and tranny (installed a new shift kit and an upgraded torque converter), took his truck down on Thursday night, and had it back up and running late Monday morning. No other downtime since last Summer.
Maybe it isn't 650 r/w hp, but still very nice anyway, and I might settle for that and having a truck on the road for the last several months.
Once you DO get the turbo done, if the motor holds together this time, you should be in for the ride of a lifetime that first 1/4 mile...
But, imagine all of the interesting reading we all would have missed out on had Neal gone that route.
Neal, my hat is off to you for your patience and perserverence!
THANK YOU for LOTS of good reading...
AWESOME Truck, but like Rob02, whenever you sell it you should easily be able to recover at least 30-40% of just the $$ you have in it, not to mention all the time and aggravation.
