THE H.P FREAK'S "SUPER FREAK" 5.4 BUILD UP!! (pics)
HI!... Just an update :
MIKE T overnighted my new chip to me. I got it yesturday. I have to swap out valve covers and re-TQ the head studs, fix a minor oil hose leak, and finish off the electrical and it will be ready to go by SAT night I hope. Will get a vid as soon as I can.
Just a few observations...
It is my guess that the reason you burnt up valves on your old motor is because of distribution issues. I would run quickly away from the wet kit with that intake.
You have plenty of injector for a dry kit, and way too much for motor, and not enough for a turbo kit.
I don't think I would have gone with the Mahle, especially high heat/hp applications, but that is my opinion. Are those rings file to fit? What sort of compression?
HI!... No distribution problems, just bad advice and damage caused by leaning the fuel jet out.
As for a dry kit, don't like them will never run one. Actually the 42LB'ers are not too much, and it will be tuned accordingly. I will be going with 60LB injectors once the turbo set-up is installed.
Actually I chose the MAHLE pistons I'm running for their heat and H.P capabilities. Pistons yeild a 8.4:1 compression and are designed for SC/TURBO applications with lots of boost. I know of people running the MAHLE's that are pushing over 25LBs of boost and 1400 - 2000H.P with no problems. They are one of the best pistons for the modular engines. That's why I researched and chose them over their less than good counter parts, JE, PROBE, KB, MANELY which alot of people here and on other boards have had problems with.
' so u could tell i was being sarcastic. Sorry.
Lookin good Neal!
