Last edit by: IB Advertising
Do you need to fix a spark plug blow out? Forum members suggest various methods to fix the problem. The methods include:
Read the full discussion below to find out the preferred methods.
living with ford spark plug blow out problem
Send me an e-mail, or give me a call and I'll give you a price on the 5553 kit that can't be beat, guaranteed...it's what I do! If you don't know who I am, search a few pages back.
1-888-AMSOIL-4
amsoil@galaxylubricants.com
1-888-AMSOIL-4
Well, add me to the list! 98 4.6 4x4 (122 k miles), launched #3 leaving a stop light this morning, helluva racket, thought a motorcycle had hit me.
Heard a swishing sound on Saturday, tried to localize it
, thought it was idler pulley and tensioner (both really stiff, bearings shot). Already had suspension parts on order (ball joints, control arms and wheel hubs) following hunting trip this year, then bang!
Guess it was blow-by I was hearing after all.
Local indy shop says they can do the insert (not helicoil), for about $350. Friend has a kit with 3 leftover inserts but he's out of town for a few more days. Deciding if I can wait until he get's back, or if I should suck it up and have shop do it. Only other available vehicle is motorcycle, and it's cold in the morning!
Guess it was blow-by I was hearing after all.Local indy shop says they can do the insert (not helicoil), for about $350. Friend has a kit with 3 leftover inserts but he's out of town for a few more days. Deciding if I can wait until he get's back, or if I should suck it up and have shop do it. Only other available vehicle is motorcycle, and it's cold in the morning!
New member of this particular club! 5.4L 2003 Expedition, cylinder No.3 at 111,800 miles. A local shop was able to put in a new plug and coil. I drove the family home, about 125 miles or so and now I need to FIX IT!
I am now a memeber of this club. Back in October I noticed a ticking sound and knew it was probably a loose plug based on this posts in this forum. The truck had 156k miles on it and never had the plugs changed. When I changed them the #3 plug was loose. I torqued it down and did not have a problem until this past week when the #3 plug ejected.
I have since purchased a Timesert #5553 kit and plan on installing the insert tomorrow. I am going to try and salvage the COP by using JB Weld to re-attache the broken off bolt ear. Has anybody tried that?
14 is why it blew. Retorque them all to 28 before more of them blow. The threads will hold to 100, don't worry.
www.blownoutsparkplug.com - I think it's FAQ #49. I'd check but the site isn't responding right now.
How the ears break off, since you have one broken: Some aren't happy with their coils loose and washer up the coil bolt in an attempt to get them tighter. Well, that isn't needed, in-turn, doing so breaks the ear, usually immediately.
It took several hours to install the insert in #3 since I did not have any right angle power tools for the counter bore and reamer. I retorqued all of the pugs to 28 ft/lbs. I used JB Weld on the broken ear of the COP. The cheapest price I found for the COP was $41.00 from Autozone. Who sells them for $10.00?
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
You can purchase individually as well.
http://cgi.ebay.com/NEW-IGNITION-COI...item5886071f9e
There's a whole set of 8 for what you would pay for 2 at Autozone and they are better coils with a lifetime warranty.
2004 with the new body style and 3 valve motor. Then there are issues of getting them out. This is true to sometime in the middle of 2008 when they switched to a more normal style of spark plug. In 2008 if you have brown COP boots you have the new plug. I have not heard of any issues with the latest set up.
I'm BACK.
Back again, but thankfully not for myself.
In 2003 I repaired my 97 Expy 5.4 #3 plug with a Big-sert 51459. It had 112k on it at the time, and now I've got about 150k. No other problems, knock on wood. I purchased an extra 51459 at the time just in case.
Yesterday my bro-in-law was changing plugs on his 2003 F150 4.6, and had trouble getting #3 back in. He describes the plug not going in straight and he can't tighten it all the way (socket gets wedged eventually). That's what I remember happening when I tried putting a new plug in before doing the repair. I think he's got thread problems too. What do you think?
Will the 51459 insert I have work on his 2003 F150 4.6?
I told him I'd come help him fix it if the insert will fit. My back is already dreading it. Fortunately, he's a diesel mechanic and should have access to some air tools.
Thanks,
Dave
Thanks,
Dave
