Old Apr 13, 2015, 12:49 PM
How-Tos on this Topic
Last edit by: IB Advertising
Do you need to fix a spark plug blow out? Forum members suggest various methods to fix the problem. The methods include:
        Read the full discussion below to find out the preferred methods.
        Print Wikipost
        living with ford spark plug blow out problem
        Old Apr 30, 2022 | 05:52 PM
          #541
        projectSHO89's Avatar
        Seriously??? This stuff was designed over 25 years ago and this version of the modular engines has been out of production for almost two decades.
        Leave it rest...
        Old May 24, 2022 | 01:32 PM
          #542
        Titan motors su's Avatar
        Originally Posted by syncmaster
        This is a thread I am starting to have a collection of ideas on what to do if you have a spark plug blow out and preventive methods. If you have had a blow out please list the particulars in one of the many threads below:
        https://www.f150online.com/forums/sh...5&pagenumber=1
        Please only post in this thread if you have something to add about what to do about this problem. (we already know FoMoCo sucks)
        If you have blown a plug I'm sure your very angry and if you read the threads above, there are many others that feel the same way you do. But it's time to deal with reality, Ford screwed up on the spark plug head design for the trition engine 1997 to 2003 , Whether you have the old style plug with 3/8" of thread or the new style 3/4" of thread you still only have 5 or 6 threads in the cylinder head holding the plug in. There is a good chance a plug will work it's way loose sometime during the motors lifetime from engine vibration.
        If you want to argue about percentages please do it on one of the threads above there are many arguments there already. It doesn't matter how many engines this happens to ..... It has happened to you and your looking for help. This thread is to inform people about their options if or when it happens to them.
        I made the mistake of paying a ford dealer $1700.00 to remove one head and install one insert... because I wasn't informed.
        PREVENTIVE MEASURES:
        One of the easiest: things you can do is listen to your motor when it's idling , prior to blowing my plug I heard a ticking sound like a valve lifter. If you read the threads above you will read that alot. You will also read how the person heard a slight exhaust leak. This sound, is one of the spark plugs worked loose and is vibrating up and down in the threads as the piston sucks and exhausts. There is a good chance that the threads are already slightly damaged. I wouldn't torque this plug to the max spec... maybe something a little less than max.
        you need the correct tools to check your plugs , a deep socket like this:
        Snap-on deep spark plug socket # S9720KA
        Don't use a regular spark plug socket.
        when you are tightening the plugs, if you don't have a extra long socket, the socket with a extension might bind against the spark plug casing wall and you think the plug is tight when it's not.
        and a short handle (clicking type) lb/in torque wrench.
        ( the torque for this plug is 7-14 lb/ft or 84-168 lb/in )
        Always work on a cold engine.
        If you have a blown plug you have the following choices:
        If somebody tells you they can re-thread it, save your money... your setting yourself up to be stranded again in the future. That is totally unreliable.
        a NEW MOTOR, here is a link:
        http://shopping.netledger.com/app/si...&category=2005
        Just remember you will be installing a new motor with the same poorly designed heads that got you into this mess.
        a STEEL INSERT here is a link to a insert kit:
        http://www.timesert.com
        the kits cutting tool/counter bore makes the insert flush with the cylinder head and the insert is the bevel seat for the spark plug.
        Heli coils are available but they are not as reliable as a insert.
        Then there is replacing the head. I don't have any links for this but I am sure any ford dealer would be glad to do that for you as the drool drips from his mouth. your talking 3500 to 5000 dollars. And when it's done.. the heads have the same 5 threads holding the plugs in so you have the same potential for a blow out.
        I have never installed the bigserts but they look like the best option to me. I like the way they permanently self lock into the head the first time you install the spark plug. I would like to hear from anyone that has used this product.
        right now we have cylinder heads with the spark plug hole as follows:
        bevel seat, 3/8" of no thread then 3/8" of thread which the old plug with 6 threads screws into.
        so, if and when we blow a plug , when you remove the head we do all 4 holes with a 3/4" long insert like to the ones shown in the link above.
        the insert will be threaded into the 3/8" of no thread area and the 3/8" of the damaged thread area . That would make for a strong reliable mod.
        The installation kit# 5141 costs-> $127.00
        each insert# 51459 costs-> $7.57
        these #'s are for a 1998 ford 5.4L engine.
        *update* here is a link to me installing the big sert in all 8 spark plug holes. (lots of pictures)
        http://www.angelfire.com/biz/gobingo/index.htm
        If anyone wants to email me direct --> doncarl@mail.com
        GOOD LUCK !
        how's it going everybody first let me start by saying scandalous bullcrap actions of Ford's actions milking everyone for their hard-earned money with no responsibilities held on their part for the Titan Motors spark plugs blowing out is janky to say the least well if you , like me living paycheck-to-paycheck it's kind of hard to have everything done all at once I've blown 4 spark plugs out blowing apart my coil pack apart for the Titan motor has an individual coil pack per cylinder. Sometimes it can be difficult but for the most part it's a pretty simple fix that you could do yourself you don't have to remove the cylinder head or anything like that you can get **** with new sleeves made out of aluminum which works basically okay does the aluminum mashes down when you insert it with the J-B Weld or permanent Loctite on the threads after you've drilled and tapped the spark plug hole mind you I recommend packing a bunch of Grease on to the tip of your drill bit which is got2b the right size for the sleeve that way the metal shavings don't fall into the cylinder head or you could squirt some old school shaving cream the phone puffy kind into the cylinder head before Drilling and all the shavings will be suspended in the shaving cream then just bump your motor over without the spark plug in it and it blows it all out clear I've even had to use a brass plumbers fitting drilled and tapped my own threads through the center of it for my spark plug and the outer threads because spark plug hole too large for the aluminum sleeve and I've had pretty good luck so far and I drive my truck and very hard it's a 2002 Ford F150 4.6 L hope this helps anybody on a budget
