Just died...
Just died...
My 2004 F150 has been running fine, went outside to go to work this morning and it started fine, I put it in reverse, backed up a lil, put it back in first and it chugged almost like I didn't give it enough gas (it's a manual transmission) and then died. Now it wont start at all. The engine turns over, but just wont fire up. I am thinking the fuel pump or the ECM, but was wondering if you guys had any other ideas.
Check the inertia switch- I think the standard location is passenger side kick panel. Also check the fuel pump relay- under the hood. If you have the tow package you can switch relays.
Both checks are much cheaper and eaeier than changing the fuel pump just cuz!
And yes do listen for the pump to run as mentioned earlier.
You don't show where you live. If it is in an area where there is lots of corrosion or rust, you might want to read this:
https://www.f150online.com/forums/ar...placement.html
I would say check these in order:
1. Turn key to "Run" and listen for the fuel pump. Usually there is a slight squeak from the pressure.
2. Check the Inertia Switch.
3. Check THEFT indicator on cluster. Does it flash when you turn the key to "Run"?
4. Check the Fuel Pump Relay. If in doubt replace it.
5. Check all plugs and plug wires.
6. Check fuel filter. Test for water and correct fuel. Ensure there is plenty of fuel.
7. Check ECU by pressing and holding the ODO RESET button on cluster while turning key to "Run" and see if it can do the self-test and such. If it displays stuff, more than likely your ECU is still functioning normally.
8. Check for any ground wires disconnected or corroded in the engine bay.
9. Change fuel pump.
10. Change/Reprogram ECU.
Just a few things... I'm a She and its a 04 heritage with a manual... yep its possible. I want to thank everyone for all the help, we are still working on getting things checked as out here in northeastern colorado, we've been in the middle typhoon it seems like. There have been maybe 5 minutes in the last two days that it wasnt down pouring rain.
Thanks again!
Thanks again!
Okay guys and quite possibly gals, I got the truck started, it was a blown fuse, but now I need some more help. The next day I blew the same fuse after I replaced the fuse it has been fine since. So my question is could there be a short from the fuel pump to the fuse box? Does anyone happen to have a wiring diagram for the fuel pump, so I can follow the wires and see if there happens to be a frayed or exposed wire?
Thanks again
Krystal
Thanks again
Krystal
