Leveled out & 33s
Old Nov 17, 2008 | 07:54 PM
  #31
FI10Fires's Avatar
im contemplating adding a small lift in back, I took off my spare from under the truck and it let the back lift up a little bit so it looks more even, but im gonna need a small lift in the back if I put my other spare in the back of it.
Superchips Tuner.......installed the mileage XS Save tune, took gas mileage from 175 miles on a half a tank and put me at 220 miles! So definitly good results so far at least from what it was :-)
Old Nov 17, 2008 | 08:27 PM
  #32
ChrisT's Avatar
That tune must have stuck your gas needle then..... 230 miles for half a tank? C'mon.......
Old Nov 17, 2008 | 08:57 PM
  #33
FI10Fires's Avatar
stuck my gas needle? what do you mean? I ment to hit 220...is that supposed to be bad? for me at least its good, cause I dont drive my truck much past a half a tank.
Old Nov 17, 2008 | 09:05 PM
  #34
ChrisT's Avatar
Unless I'm misunderstanding you, you're saying you used to get 175 miles to a half a tank and now you're getting 230? To me, that's a pretty significant increase, but I see you just got your speedometer corrected too so perhaps that's the reason. Either way, we have similar set ups as far as engine, tires, custom tuning, etc. I wish I got that good a mileage.
Old Nov 17, 2008 | 11:20 PM
  #35
FI10Fires's Avatar
I mean im just saying as far from when I put the tires on without the correction it was reading 175 which sucked, but now that I had the tune and got everything set to normal with the mileage tune its to 220....most if not all my driving is highway so Im guessing it helps to an extent..........Now I havent tried the performance tune to see what mileage I get, but ive installed the tune before and it gets the wheels rollin with no problem
Old Nov 18, 2008 | 12:45 AM
  #36
I gotta believe this...
I noticed when I run the truck semi-hard, she'll get quite good fuel mileage... if I run it too low, it will get horrible gas mileage. If I run it too hard, it will get horrid gas mileage.
The 4.2l v6 is an odd engine to please sometimes. But it gets the job done.
I can't wait to do some other mods to it soon... I just need some free time to get it to my friend...
My plans on my truck are:
New tires
Smoke Stacks (done right for a gasser, not some 6" exhaust stack...)
Moon Visor
Side Steps
Custom Retracting Steel tonneau cover
Old Nov 18, 2008 | 02:35 AM
  #37
Fifty150's Avatar
Have you all considered figuring out what your actual MPG is?
Old Nov 18, 2008 | 07:58 AM
  #38
ChrisT's Avatar
Oh I know what my actual mpg is, I was more surprised in the increase he was seeing based on his tuning. Now I see that his speedometer was corrected between the two numbers stated so it makes perfect sense now.
Old Nov 18, 2008 | 07:17 PM
  #39
ModBargains's Avatar
Looks great!
Old Nov 25, 2008 | 01:56 AM
  #40
islandfordguy's Avatar
Hey folks, got my level on the front end and put new rims/tires on. still need to put the rear blocks in, but it's a whole new truck that never scrapes bumper anymore on inclines. give it a look if you please
https://www.f150online.com/forums/me...picture-a.html
Old Nov 25, 2008 | 10:00 AM
  #41
Looks good.
Old Dec 14, 2008 | 08:32 PM
  #42
alex7191's Avatar
FI10Fires
Truck looks great!
