4R70W 97 and up differences & interchangability
Old Dec 23, 2024 | 01:23 AM
  #76
Southwest complete's Avatar
Ford transmissions are kind of a flaky thing but a 97 truck sits alone and it's year
Originally Posted by Southwest complete
You are very correct I put a 98 transmission in a 97 and had a shift sensor trigger on my dash I didn't get to it in time or whatever and it ended up screwing up the transmission shifted very violently from second to third unless you let off the accelerator now I'm in the yard right now putting the original transmission back in
97 kind of sits alone not a lot of parts interchange
Old Dec 23, 2024 | 09:11 AM
  #77
rivieragsx's Avatar
Originally Posted by glc
No. Incompatible without taking the transmission apart to swap the output shaft and tailhousing. Transfer case has nothing to do with it. Also, if the 97 is a V6 and the 05 is a V8 the bellhousing patterns are different. You can't use anything newer than 03.
Ok thank you . I think I found one from a 99.
Do you know if Jasper remanufactured transmissions are any good?
I found one with 30,000 Miles on it
