4R70W 97 and up differences & interchangability
Old Dec 27, 2021 | 09:39 AM
  #46
What engine do you have?
Old Dec 27, 2021 | 03:39 PM
  #47
KINGVAPOR69's Avatar
I have a 4.6L Triton, if you need any other info- please, I don't mind at all.
Thanks so much, I appreciated it
Old Dec 27, 2021 | 04:28 PM
  #48
You have a 4R70E, and all I see is a 3L3P or a 5L3P for a 2005. I show the 4L3P is a 4R70W and was used in the 2004 Heritage. I show the 3L3P was used in 2004 (new body style) and 2005, the 5L3P was used in 2005. I'm guessing either will work as long as it's out of a 4.6 4x4.
Old Dec 27, 2021 | 04:50 PM
  #49
Is it possible the 3L3P,4,5, etc are just build codes and any 4R70E will work in my truck (as long as it's 4x4, and otherwise matching)?
Old Dec 27, 2021 | 05:25 PM
  #50
I would say that any automatic out of a 2004 or 2005 F150 4x4 with 4.6 should work, 2005 preferred.
Old Jan 2, 2022 | 04:13 PM
  #51
Raulsmonte's Avatar
1997 to 98 swap 4rw70 4x4
So if I change a 1997 4x4 4rw70 with a 1998 4x4 4rw70 and repin the trans harness fron the 9 pin white to work with the 7pin black harness. Will it work is there more to it
Old Jan 2, 2022 | 05:11 PM
  #52
That should be all you need.
Old Jan 2, 2022 | 05:56 PM
  #53
Raulsmonte's Avatar
Originally Posted by f150man2000
i need the to know the repin i bought a 97 4r70w for my 2000 f150 before knowing that they didnt swap out
Originally Posted by glc
The repin info is a couple posts up, actually posted twice.
if the repin is done will the transmission work properly .
Old Jan 2, 2022 | 11:04 PM
  #54
Post #6:
In 98 the internal electronics changed on these transmissions. What you have is a common problem that most get when they swap in a newer transmission into a 97 or older vehicle.
You can either fix it by swapping the internal wiring harness and all the solenoids from the old transmission into the new one or by repinning the harness on the truck to work with the newer transmission.
​​​​​​​Posts #34 and #35 have the repin info.
Old Jan 25, 2022 | 04:41 PM
  #55
DNT's Avatar
DNT
Hello will a 1999 ford mustang 4.6 4r70w trans work in a 2006 ford f150 with the 4.2 that also has a 4r70w transmission?
Old Jan 26, 2022 | 12:10 AM
  #56
Nope. You are stuck with a 2006 4.2 F150 transmission. You have a 4R70E. Get yours rebuilt, used ones are expensive.
Old Jan 26, 2022 | 12:24 AM
  #57
DNT's Avatar
DNT
4r70e
The only trans that will work in my 2006 f150 with the 4r70e are 2005-2008 f150 with the 4.2 and the lariat of the same years with 4.2 and the 2006 lincoln I’m just trying to get an idea of what will work
Old Jan 26, 2022 | 10:27 AM
  #58
Lariat and Lincoln transmissions won't work, they don't have a 4.2. The 4.2 has a different bellhousing pattern than any of the V8's except for the old pre-1997 302. Nothing before 2005 will work because of a different output shaft.
Old Sep 25, 2022 | 03:44 PM
  #59
crzyhr1989's Avatar
repin
Originally Posted by rhislo
Are there any differences between the years of the 4r70w transmission? Is a 2003 4.6l 4r70w a direct replacement for a 97-04. I've seen the 01-04's are plug-n-play, but what makes them "different" then a 4r70w from 97-00. I understand the torque converters coincide with the engine displacement.
I would think all have the basic Shift solenoid #1 & #2, TCC, & EPC, Temperature sensor, VSS and OSS, and Transmission Range sensor.
I can't imagine there being that much difference...Just wanted to ask the pro's!!
can you send the repin diagram to me pleaese crzywork1989 gmail.com
Old Sep 25, 2022 | 09:43 PM
  #60
Repin diagram is in this thread in post #34.
