4R70W 97 and up differences & interchangability
Old Sep 11, 2019 | 11:33 AM
Tristan Dedon's Avatar
Originally Posted by rhislo
Yes...would love the repin info. If it'll work by just repinning the connector, that'd be great...and easy.
Did you get this repin info? I'm dealing with this issue on my truck currently. I know this thread is old but it's all I've got right now. Thanks.
Old Sep 22, 2019 | 10:45 AM
Fbird's Avatar
1997 5.4
Old Sep 23, 2019 | 06:13 AM
Eric Jackson's Avatar
1999 to 2007 trans swap
Originally Posted by glc
A 99 should work in a 01.
Has anyone took a trans from a 2007 and put it into a 1999 2 wheel drive not sure if it's working correctly it shifts into 2nd but won't shift to 3rd I haven't switched the speed sensor plug to match the trans sensor yet so it's still unplugged just need some advice
Old Sep 23, 2019 | 08:50 AM
No, that will not work without custom reprogramming.
Old Feb 16, 2020 | 08:20 PM
Jacob Alford's Avatar
Originally Posted by Darrin Burch
The electrical connector onthe truck will plug into the transmission but it won't work because the newer transmission is wired differently. I have details on how to repin the harness if you need them.
Darrin
could you please share those details with me
Old Apr 12, 2020 | 09:17 AM
Mcrotten's Avatar
2001 and 2002 4r70w transmission swap
Why are the speed sensor plugs different? My 2002 F-150 supercrew transmission blew so I got a new one out off a identical 2001 everything is the same options everything but the speed sensor plugs are different so I swapped out the sensors. Is this going to be a problem?
Old May 9, 2020 | 05:22 PM
caveman88's Avatar
Question i have a question
Darrin
hey do you know if a 98 explorer with a 4R70W trans will work in a 98 expedition it also has a 4R70W trans
Old May 9, 2020 | 06:18 PM
Nope. Different bellhousing patterns.
Old May 9, 2020 | 07:23 PM
caveman88's Avatar
i have a question
but the huts should be there same though right
Old May 9, 2020 | 10:37 PM
The what? Disable your autocorrect.
An Explorer transmission WILL NOT BOLT to an Expedition engine and vice versa. It also may not be the same length and have the same tailshaft.
Old May 9, 2020 | 10:43 PM
caveman88's Avatar
damn it I am sorry I meant to say the guts
Old May 9, 2020 | 11:25 PM
I would have to guess - they should be, except maybe for the tailshaft. On either, 2wd and 4wd use different tailshaft housings.
Old Nov 15, 2020 | 09:36 PM
SergRoush's Avatar
My 2000 f150 5.4
So I have a 2000 f150 and my transmission recently went out it’s of course a 4r70w but I was going to replace it but the transmission Im looking to get is from a 1998 mustang gt with the 4r70w I’m wondering if it’s just plug n play. Yes it has the same tail housing
Old Nov 15, 2020 | 10:43 PM
No, the electronics are different.
Old Nov 24, 2020 | 09:28 PM
SergRoush's Avatar
Alright thanks so now I’ve got a 2002 transmission 4r70w will it work on my 2000 f150 with the electronics being the same ?
