knock sound from rear
Hey guys, got an issue and just wondering if it's happened to anybody else. Everytime i take a turn stop or accelerate (from stop) i.e. any change of motion, i seem to get kind of a "clunk" sound from what i think is the rear suspension. so if i turn left i can hear and slightly feel it clunk to the right, then i can make a right turn and feel it clunk on the left. when i go over a bump, if it's just right, i can hear it also. i've crawled under my truck and felt around to make sure the bolts are on there tight and everything seems to be good. i don't have any modifications to the rear, only a leveling kit in the front. anybody else hear this noise? it's kind of hard to explain...
thanks in advance for any advice!
like you turn at an intersection without haveing to stop , and as you start off down the next street it go clunk ?
ya my 01 has done that for-ever
it used to be my father's truck - I noticed it the first time I drove it back in 02
-I asked him about it
he said the dealer said - brakes
naw Idon think so... my rear calipers clunk when comeing to a stop but this is different
I think it's my diff locking back up after turning
my rear calipers also clunk again when starting from a stop
it's not so much a clunk I hear but rather something I can feel
though , before I got my brakes done the last time the rears would clunk when I steped on the running board - dosen't do that now but I can still fell them move when I come to a stop and start off (both)
the turning corners thing is different and I still think that's the differential locking
I had my U joints checked - nope not it
no slop at the trans or pinion gear either
I'd like to try new rear caliper mounting bolts / pins and the rubber bushings which might be worn out - presumeing it uses the mounting method I'm thinking of
Sounds like it could be the traction lock not wanting to release. I had to add 2 bottles of friction modifier to my 2000 to get it to where it would release while turning. There is a TSB on the 2000 and maybe other years. This happened a lot and the TSB said the fix was to replace the clutch pack and reduce the preload shims by 0.010". I just added the second bottle of friction modifier and fixed it.
