SuperCrew
How many miles and problems
Old Jan 6, 2005 | 01:47 PM
  #61
hedperocks's Avatar
85,000 on my 2001 5.4 4x4. Superchip, Ravin exhaust, K&N filter, edelbrock shocks
Had a rear differential leak (where the driveshaft meets the differential) twice. Repaired under warranty.
Somehow broke the headlight on/off **** and replaced that assembly at about 50k.
Old Jan 7, 2005 | 02:08 AM
  #62
snappylips's Avatar
Bought 11/02. 18K miles. Perfect. Wish I had bought two.
Old Jan 15, 2005 | 12:52 AM
  #63
fordlinks's Avatar
2001 SuperCrew, 44k miles with a transmission replacement. I bought it last month and the dealer paid for it so good for me. It's possible the previous owner beat it though. It does have a Kenne Bell supercharger.
I love my truck!
Old Oct 3, 2005 | 03:37 PM
  #64
1sawtooth's Avatar
111,000 miles and zero problems. Never been back to the dealer.
Old Oct 4, 2005 | 12:21 PM
  #65
Jeeps&Fords's Avatar
Banned for Use of Multiple Usernames
2001 Screw 4x4 5.4. Purchased in June 2004 with 28K miles, now sitting at 52K miles. No problems whatsoever.
1997 Explorer 5.0 AWD. 123K miles. No problems whatsoever.
1995 Ranger STX 4.0 4x4. Had 155K miles when I traded it for the F150. Only problem was a leaking water pump at about 10K miles and that got replaced under warranty. Still had the stock clutch.
1986 Mustang LX 3.8. Had 185K miles on it when we sold it. Last I heard it was over 250K and still running strong. Had to do a trans at about 60K, but that was due to my own stupidity, and I put a timing chain in it at about 150K just for piece of mind (I had the cover off to fix an oil leak anyway). Other than the trans, no problems at all.
And people wonder why I stick with Fords.
Old Oct 5, 2005 | 03:36 PM
  #66
FORDWORKER2000's Avatar
2005 F-150
Has Anyone Had Any Major Problems With Their 200-05 F-150's I Have 10,200 Miles On Mine And Have Already Hade A New Rear End And Drivshift Because Of Slippage
Old Oct 5, 2005 | 04:11 PM
  #67
At 1600 miles, I had to have the throttle body replaced. Been like a dream truck since then, now have 13,000.
Old Oct 5, 2005 | 05:54 PM
  #68
shoeynne's Avatar
yea ,my o5 screw at 800 miles had rear end replaced,had a/c recharged,also had front end work on it twice,ailment promblems,also still not happy with the fuel milage,rough idle and sluggish,i have the 5.4 engine,so will see how it goes from there
Old Oct 19, 2005 | 07:13 AM
  #69
jpdadeo's Avatar
26K and problem free but the euphoria might be coming to an end.
Originally Posted by tschaid
(Snip
but, we were 2 for 2 in breaking them off inside the plug well. And, the Ford Mechanic was 6 for 6 in breaking the remainder off.
To change 8 plugs in my truck cost nearly $1700 total.
https://www.f150online.com/forums/sh...d.php?t=210634
Check out this thread to see why
Old Oct 31, 2005 | 07:28 AM
  #70
msgtcarew's Avatar
02 Screw Lariet 2x2
52k miles, new tires/brakes/ignition switch. Windshield leak took out power windows, need new PCM. PCM covered under extended warranty leak covered by checkbook, even though Ford replaced seal strip 1 yr ago under warranty. 5.4. Awaiting cruise control module.
Old Oct 31, 2005 | 10:19 AM
  #71
shoeynne's Avatar
shoeynne
Member Join Date: Sep 2005
mow at 1200 miles they are replacing the transmission
Old Oct 31, 2005 | 01:26 PM
  #72
SM's Avatar
SM
Our '01 Screw has been a good truck since we got it new in August 2000. The biggest problems have been the Ford fiasco with the standard radiator vs. larger radiator and a whining rear axle. Ford replaced my perfectly good standard-size radiator with a larger one at no cost back in '01, since that's what I paid for with my trailer-tow package. A cooperative local dealership rebuilt the whining axle twice, and finally replaced the entire assembly, (all under warranty) which finally stopped the whining. The DPFE sensor and the IAC valve have also been replaced.
Other than those things, at five years and 101,000 miles everything else is original, including battery, starter, alternator, transmission, and brakes. Original General tires, crappy as they were, still lasted 86,000 miles. I keep track of every gallon of gas, and it has a long-term average of 18.9 mpg since the day we got it.
Old Nov 1, 2005 | 06:52 PM
  #73
2yr old. 2003 4.6 4x2 Only problem so far was one of those lights inside the dash behind the ac controls went out, took an hour or so at the dealer to get fixed.
Factory tires sucked. Ive replaced two of them and should have replaced the other two many miles ago
Oh and im at 26k the light went out around 17k or so.
-Patrick
Old Nov 1, 2005 | 07:03 PM
  #74
jpdadeo's Avatar
25,776K and all is well except for the spark plug dilemma
look good huh
Old Nov 1, 2005 | 07:53 PM
  #75
shoeynne's Avatar
now at 1300 miles transmission been replacedand they are changing out thetires to a differant brand
