Dyno Sheet & Video 475RWHP/532RWTQ
Old Nov 9, 2011 | 08:27 PM
  #46
slothman86's Avatar
Originally Posted by FATHERFORD
don't be scared... Lighting guys run 18lbs on factory rods. The 18lbs of boost isn't the problem, it's the detonation, or the just throwing the rods around (cruise at 2000rpm, punch the accel, switch gears, ramp to 4800rpm) that kills the engine.
how much power/boost can the 5.4 (2 valve) non-lightning motor handle ? I know the pistons are weaker and the comp ratio is higher so what is a good amount of boost with a conservative AFR?
Old Nov 13, 2011 | 07:52 PM
  #47
jbravo316's Avatar
Originally Posted by javier garcia
Is their anyone running mote psi than u twinskrewd?
I am running more boost, and with a built 4.6 using a Procharger. Don't know what power is cause Mike Troyer has had truck since April, but I probably won't see those kind of numbers.
Old Nov 13, 2011 | 07:54 PM
  #48
jbravo316's Avatar
Originally Posted by twinskrewd
Thats the hard part! Its hard not to use that power.
Must be nice to have a problem like that.
Old Nov 14, 2011 | 06:24 AM
  #49
NOLAGT's Avatar
April...yikes. With a built 4.6 and more boost I bet you could see higher than those numbers.
Old Nov 14, 2011 | 07:53 AM
  #50
javier garcia's Avatar
That's good jbravo316,but I meant
On a 5.4 3v. I'm really impressed with twindkrewd numbers si I can only imagine what a built engine
With h/c with high boost 16+ will put out.
Old Nov 14, 2011 | 12:53 PM
  #51
FATHERFORD's Avatar
650-700rwhp is about all that Whipple is going to breathe on pump gas. Maybe slightly more.
Old Feb 21, 2012 | 08:58 PM
  #52
builtFtough4.6's Avatar
beast mode truck brother. see its been a few months ,hows she running ?
Old Feb 21, 2012 | 10:13 PM
  #53
twinskrewd's Avatar
Strong as ever. Looking forward to some drag racing as spring roles around. If she'll dead hook at 1.7 like she did this past fall I hope to run a 12.5 now that the plugs are fresh. Also wanting a dyno run at sea level.
Old Feb 21, 2012 | 10:29 PM
  #54
IR0NS1N's Avatar
You ever think about doing cams? Im thinking this summer I may do some detroit rocker blower grind cams. They only make about 25-30RWHP from what I see but they aparently sound badass too. I want to put them in my truck and see what I get power wise on my VMP tune with the cams before I increase PSI to reach that 450RWHP goal...
Old Feb 25, 2012 | 10:35 AM
  #55
twinskrewd's Avatar
I would love to do cams and something with a badass idle too. Just holding out till I go with a built motor. Sure I could reuse them if I installed them now and go built later but with with my luck they would somehow end up ruined when this motor goes. Look forward to hearing your results!!
Old Feb 27, 2012 | 08:39 PM
  #56
Always wanted to ,what about some real mild degree cams on a stock 4.6L 3v?? will be blown eventually, need some scratch though, figure by the time I hit 50K on the stock motor I should be game.
12.5s pretty quick for a SCREW anyway ,hell I'd take a 13.1 I mean...thats a freakin truck ya know what Im sayin! disgusting rides men love em
Old Feb 29, 2012 | 05:10 PM
  #57
Leonardo Agueci's Avatar
Hello, I write from Venezuela, surprised by these numbers, I congratulate you greatly, now, I will take the opportunity to ask you a question, given your vast knowledge with whipple, I just installed my supercharger pulley with 3.25 inches, 39 pounds injectors, I have understood that this block of 3.25 I get about 9 psi of boost, even though I have a problem of gasoline at 4000 rpm which I will settle with 2 pumps in parallel, my supercharger pushes no more than 5.2 psi, my mechanic did not is the reason, and I'm concerned, that you think may be happening. Thank you.
Old Feb 29, 2012 | 05:45 PM
  #58
IR0NS1N's Avatar
3.25" pulley should be 8PSI. If you have fuel issues at 4000RPM they must be fixed before you continue to hammer on it. Stock fuel pump is more then enough for 8PSI. You need to get a custom tune for the 39lb injectors from any of this places
Troyer Performance
http://www.troyerperformance.com/cgi-bin/ppistore.pl
JDM
http://www.teamjdm.com
VMP Tuning
http://www.vmptuning.com/store/index.php
Old Mar 3, 2012 | 09:37 PM
  #59
twinskrewd's Avatar
Me? Yes 5.4 3v. Never cracked a seal on it.
Old Apr 28, 2013 | 01:01 PM
  #60
TheBlackPearl07's Avatar
Badass pickup man!!! What pulley setup are you running?
