Dyno Sheet & Video 475RWHP/532RWTQ
I'm getting a tune from JDM. Had a nice conversation with Jim Jr today. Also going to install the 90mm Ford Throttle body. Can't wait to get to the track again.
Gotcha. Sorry. Had a brain fart. I was thinking of a Foose truck with a Roush blower. Duh the Saleen truck would have the Saleen blower.
The 2.8 is the smallest pulley for the Saleen. Next step is a Metco crank pulley. Regardless a 2.8 should be making lots of boost. The 3.0 is said to make 13-14psi. http://vmptuning.com/saleen-pulley-products/0705-300/
I agree with Irons1n. Call JDM and talk with them. Make notes of all your mods so you will be prepared for the conversation. They can help you out in a big way. Fatherford is pushing 450rwhp + on his Saleen. No reason you shouldn't be too. Also have you run the truck at the strip? Track numbers speak volumes over dyno results.
We talked about it. I had heard they installed one on an F150 and wanted details. Turns out they just sold one to a customer for an F150. The truck has not run yet. Still in build mode. But he said it should work without tuning. May need an idle adjustment and watch a/f's. Regardless, I'm getting a tune from them. I'm tired of the long starts and flat spot in Troyers tune as well as the cold natured throttle issues. He can't make it right so I'm done with him. The flat spot is not huge issue and as we discussed some time ago i didn't even realize the cold nature problem because I never drove the truck cold. But now I know about it so it bothers me. I've spoken to Mike as recent as 3 weeks ago. He still needs the truck for "weeks" to work it out. Nope!!! Not happening. JDM to the rescue.
Not trying to run Mike in the ground. I've seen people call him a crook for years. I won't go that far but I will say I've seen and heard to much. Even reviewing some of my own experiences with him I can see where he got me where ever he could.
Yes the inlet has to be larger. I measured 1-2 inches of vacuum in it when boost reached 11-12psi. I have what I need to make it 4" from when I fitted the AccuFab tb. I'll keep the 95mm maf housing. No need to change it. Even with a built motor she'll never breath more then it can flow.
I don't expect huge gains. Kenne Bell's test showed a 1/2psi of boost lost for every inch of vacuum in the inlet. So I might free up 15-20hp. Per Jim Jr inlet restriction will also increase air charge temps. So I may benefit there as well.
Yes. Bone stock. Never a seal cracked. Cool charge temps and the efficency of the Whipple are the reason. There's a lot left on the table I just can't touch because the rods won't take it. Imagine 5-6 more degrees of timing and an 11:8 A/F. Thats at least 50hp.
