Yes............... Another lightning swap!!!
No i'm not doing it, a machine shop is. What dabs?? Where the front cover meets the block and the heads??
Yes where front cover meets block and heads oil pan and cam covers! The head gaskets are thick and leave a nice gap that probably the cam chain sling oil against. And you don't want to pull the fron cover off once its all back together. A real PITA!
Same heads too!
There is a post I believe on NHTOC that shows plug slection and gap versus boost, if you can not find I think I have it stored somewhere.
Just saw some head studs cheap, maybe ebay?
Ok thanks guys!!! Yeah I got the head studs already, $215 from summit.
The pulley setup I have is gonna be around 16 lbs but not sure how accurate that is. Thanks..... It's getting there. Should start ripping the truck apart the middle of the month... I'll be sure to take plenty of pics. I can't wait!!!
