ART King Ranch build thread
Old Oct 11, 2011 | 12:50 AM
  #46
SLW-SVT's Avatar
TRUCK OF THE YEAR - 2011
What's Travis charging you to align it? Need to toe mine but don't wanna pay 60+ just for a toe adjustment.
his boss was the one who took me in after hours. the first time was 50 and every time after is 20. He pretty much let Travis do it this time (still learning)...so I'm not sure if he's ready to take customers?
Originally Posted by azmidget91
I just wish I had the money to execute all of my ideas and theories I have
Wish we could have discussed your ideas and theories before I bought all this crap..but fwiw I did buy it for the convenience that it offered...or was supposed to offer
Old Oct 11, 2011 | 10:33 AM
  #47
thejake1989's Avatar
ill have to text him this week and see then. its just toe alignment for now and im thinking its just slightly off and not really worth me paying someone i dont know to check it out.
Old Oct 13, 2011 | 10:05 AM
  #48
fine_style150's Avatar
i'm subscribing just because this build thread is awesome, i wish i could have the flexibility of airbags on my 4x4 without a actual lift and not do damage to my cv's, but i only know so little and have next to nothing to spend
will you keep the stock wheel+tire combo once your laying running board?
Old Oct 13, 2011 | 08:29 PM
  #49
SLW-SVT's Avatar
For now the tires will do. I have no intentions of changing the rims OEM FTW!
Old Oct 13, 2011 | 08:56 PM
  #50
SLW-SVT's Avatar
So I was chasing a leak for a couple of days this week..troubleshooted everything and ended up with my tank being the culprit. I pulled the tank and took it to my welder and he patched it up for me..I got home last night and put it back together and the tank wouldn't build air pressure even though both compressors were running..I finally put a milton male adapter on my drain valve and filled up the tank with my air compressor in the garage. After troubleshooting all morning I finally realized that the check valve attached to the compressor was checking air in both directions...I found that one compressor can fill the truck up when the pressure is 85psi and above but below that it just doesn't work. I've been meaning to order some check valves because whenever I drain the tank (or there's a leak) the bags also leak.. So I will be putting two check valves in between the tank and the valve block..I also ordered some exhaust mufflers so I can silently drop
While I was at the welders last night he told me his plans for the back. He's going to move the bags to right inside the frame and make new mounts on the top and mount the bottom to the airbar. He's going to notch the frame as high as possible without cutting the bed and cut out the spacer for the carrier bearing. I would love to switch to a watts link but will be sticking with the pan hard bar for now. He's going to adjust that so it doesn't pull the axle of far over when aired out. Hopefully this happens before winter...
Before that happens I need to trim my fender flares and possibly the fender lip..any advice on the best way to do this would be helpful.
Old Oct 13, 2011 | 11:57 PM
  #51
coobies5's Avatar
i have A (one) ss braided line from a old compressor just laying around with the built in check valve, let me know if you want it neil.
Old Oct 14, 2011 | 12:32 AM
  #52
SLW-SVT's Avatar
that would be nice! I do want it!
Old Oct 14, 2011 | 12:52 AM
  #53
coobies5's Avatar
give me a call or text me whenever you want it
Old Oct 14, 2011 | 03:44 AM
  #54
SLW-SVT's Avatar
I've been wanting to replumb the system with uniform all brass fittings and do away with plastic ones that ride tech included. I'm switching to all 3/8 line with Parker fittings. I didn't order water traps yet, I will be putting two in eventually between the compressors and the tank. I already have about 30ft of 3/8 line so I should be set. Like I mentioned earlier, I ordered 3 check valves and 2 exhaust mufflers earlier today.
8ea.- 3/8" Tube to 3/8" NPT Prestomatic Male Connector
1ea.- 25FT of 3/8" Parflex DOT Air Brake Tubing
2ea.- 3/8" Tube to 3/8" NPT Prestomatic Male 90* Swivel
1ea.- 3/8" to 1/8" Reducer Bushing
1ea.- 1/8" NPT Schrader Valve
10ea.- 3/8" Zinc Plated Steel Loop Clamp
2ea.- 3/8" Male Branch Tee
1ea.- Airline Cutter (Small)
Old Oct 14, 2011 | 02:06 PM
  #55
bankrpt's Avatar
Fyi I used hydraulic line instead of brass line a lot easier then also your fittings are pressed on to the hydraulic line might be something to look into
Old Oct 14, 2011 | 04:21 PM
  #56
SLW-SVT's Avatar
I'll look into that but I'm not using brass lines. Just the par flex plastic line
Old Oct 14, 2011 | 07:17 PM
  #57
bankrpt's Avatar
Definitely look into them well worth it just basically run the line and forget about them never have to worry about them getting hot or busting my has been on my truck for 10 years.
Old Oct 15, 2011 | 02:13 AM
  #58
SLW-SVT's Avatar
so you just screw the (3/8"?) hydraulic hose directly to the valves/bags valves/tank?!
Old Oct 15, 2011 | 02:49 PM
  #59
bankrpt's Avatar
You are correct
Old Oct 15, 2011 | 02:51 PM
  #60
bankrpt's Avatar
You can call me at 5018372532 if you need help
