My install experience - long writeup
Old Jul 16, 2014 | 01:24 AM
  #151
Chavez226's Avatar
Amp Rack...
Originally Posted by Langlowe
Well I guess it is time to update my build thread.
As I have been eluding to I added a third amp, Sundown SAX 125.2. and went active with my front stage.
I am running the Focal TNB tweeters off the Clarion XH5410 front channels at 75 watts when at full tilt. I have them high passed around 3500Hz.
The Sundown SAZ-125.2 is sending all the power it can to the Massive Ck6 mids. I have them bandpassed at 92Hz and 3200Hz.
I replaced the 4ga power and ground runs. With the reassurance of a fellow member, I was able to fit the 1/0 gauge through the same factory grommet that I used for the 4ga.
Replaced all fuse blocks and inline fuses. Made a little custom inline fuse holder that mounts to the back of the battery box. I am going for stealth. Even wrapped the cable sheathing in electrical tape to make it look more like the factory.
Made a new amp rack, actually 3 before I got it to where it is and still not happy with it.
Next steps are to carpet the amp rack and finish deading/sealing the front doors.
Here are some picks.
Parts to install
Power and Inline fuse.
Amp Rack
Question, does the amp rack get drilled into the back of the actual aluminum body? So that you see screws from in between the bed and cab?
