Using less volume?
Old 05-04-2008, 07:33 PM
J'struck's Avatar
Using less volume?
I've read that you can use pollifill or some type of stuffing in a box to "fool" the sub into thinking it in a larger box. My question is how much can you downsize the box by? I'm going with a sealed enclosure for a single 12" Kenwwod W3011, it reccommends 1.25cu ft. Is there a certain percentage I should stay within?
Also, how much space should I leave between the wall and the back of the sub? thanks
Old 05-04-2008, 08:29 PM
abervintageman4's Avatar
it doesnt make a difference, i tried it in my smaller single cab truck boxes and didnt notice a thing
Old 05-05-2008, 12:50 AM
J'struck's Avatar
Actually not to long after I posted the question I found a scale for the sub that for tighter bass I can go as low as .8cu ft...guess I'll just find something between the two.
Old 05-05-2008, 02:02 AM
Low_e_Red's Avatar
You wont get a huge difference... The polyfill trick is just for people who accidently miscalculated the airspace and need to make up .1 or .2 cuft. (And feel its absolutely necessary...)
Old 05-05-2008, 02:35 AM
azmidget91's Avatar
imo polyfill just makes it a bit crisper, and am a beliver of it and will us it in every box i make weather it is too small or not
Old 05-05-2008, 03:52 AM
ModBargains's Avatar
I put a pillow in my box which i felt was too big for the sub I have.... like you said it made it crisper and just sounded better all around.
Old 05-05-2008, 10:43 AM
Low_e_Red's Avatar
Crisper?!? If anything it would let it loosen up a bit more... Odd.
Old 05-05-2008, 04:35 PM
bigtex44's Avatar
Agreed. Polyfill makes the sub think the box is bigger, not smaller. If you want to make the box smaller to "tighten up" the bass, you can just put a known volume of wood in the box to lessen the airspace (I'd recommend glueing / screwing it down, lol, or don't slam on the brakes).
Old 05-05-2008, 05:42 PM
J'struck's Avatar
Thanks for all the info. I'm gonna do the best to keep it around where it should be...probably won't go below 1 cu ft for sure. I started getting into some designing for the consol last night. Thanks again!
Quick Reply: Using less volume?
