Box Finished, Single 12" Rainbow Profi
Originally Posted by Bartak1
Looks nice. So how do you like it???
I just got it in last night at dark, took a little ride and had to turn the sub output level down on my AVN6600 from +3 to 0, this 12" sub is hitting much harder than the IDQ 10" in a .5 box, in fact, I would say its out hitting the IDQ 10" at haft power...
As to SQ, it clearer than the IDQ... I still have to go though my song list and check it out, reset the gain, also need to run the RTA on it to see whats its showing..
I got this sub bearly used from a guy on CA.com because it would not work for his install, so I don't even think it broke in yet, so I have to keep that in mind..
But in all fairness to the IDQ, the two subs are in a differant class and one can't really compare a IDQ to a Rainbow Profi...
I still like the IDQ 10" over the ED 11Kv2 10" and it a great sub for the $150.00 range....
This is a Quote from Don,
Tim,
Its one of the best sounding subs that Ive ever used/owned or installed. Although Im a bit concerned with the mix of its paper cone with the Germs metal midbass. It wouldnt sound bad per say, but may seem a bit 'off'.
As for ideal enclosure space .. 1.4 sealed.
Awsome That makes me want to try one of those out.
I always kinda though they would be a pretty good sounding sub, never hear much about them though.
You have your own RTA?? Lucky duck :P
RTA link below for laptop and you will need a good mic..
Basic software is free, PM me if you like the program before buying the upgrades...
http://www.trueaudio.com/rta_abt1.htm
Originally Posted by tufftaco2k4
looks great. did you have to raise your back seat? also would you happen to still have your measurements i would like to make one also.
Originally Posted by F150Truck'in
I like it even more after a few Ted Nuggent tunes this evening...
Very cool...now I just need a laptop Im actually going to be ordering one in a month or so though.
What are you using for a mic?
Thanks for the link
Thanks for the link
Thanks for the link
the biggest think to look for is the feq range on the mic... a lot of real cheap mics have a range around 150Hz to say 12KHz, you will need one better than that...
