Styxnpicks install progress thread
FINALLY!!!!! got some progress done today, I ran the 1/0 power wire along the rocker pannel through some conduit and into the bed and got the frame for the amprack done.... if all goes well I should be bumping by tomorrow night
I also replaced the LAME cab to chassis ground wire on the passenger side with 4ga...
Originally Posted by Bartak1
Aww, thats all? Come on....
Bumping by tomorrow night ehh......so in about 3 weeks?
I hate having the car audio disease. I am going to be getting rid if my 15 soon and now I have the crazy idea of doing 3 12's in a center console box downfiring. I'm thinking either SSA's TC 3000s Mags if I can find them or ID MAXs. Then a few us xa2000 amps. Should do the trick. While in that process I want to get a console with the floor shifter and dis assemble it and put it into my box as well!
Originally Posted by styxnpicks
lol, you know me all too well, all i need to do is mount the amp rack frame to the bed, mount the amps and run the sub wires. rca's, remote, power, and grounds are already run. I can always tidy it up later
Sounds good, hopefully you can get it all up and running soonI think Ill also be redoing the substage soon Jwool. Kind of looking for a little more space in the cab, although I would like to be a little louder too. The Mags kick ***, but they just arent half of what they could be in the install I have them in now. Going for something that will work a little better with the space/power I have.
pfft everyone changing setups... im still trying to get mine installed... been almost three years now. o ya that cab to chassis link was HILARIOUS. the damn thing is so thin it is actually burnt a little bit. I highly recommend upgrading that thing
where is that cab to chassis ground wire located? ive got extra 4ga sitting around i might as well do that.
got the amps hung..... sorta, fastening the wood frame to the bed didn't quite go as planned. I have it screwed up along the top but I neet to make a strap support to keep the bottom of the rack from flopping around, I'l work on it tomorrow morning
no progress today, it was raining,
im building my amp rack in two peices, one peice is just a 2x1 frame the amps get attached to that gets attached to the back wall.. since I could only get the top screwed in I need to strap the bottom so it doesn't flop around and pull out long term
