Styxnpicks install progress thread
Originally Posted by styxnpicks
what? the dual optimas on the 6th page didn't entertain?
Yea they did, but only for a minute or two I since moved on.
Besides Im not one of you guys with the same vehcile so I cant yet appreciate the effort to do those batteries.
the box is almost done. all I really need to do is cut two more speaker holes and finish the maple front. had to go maple cause mdf would just rip apart.. imagine trying to pound tee nuts into 3/4 x 3/4 inch mdf every 2 inches..... ya split city... need some real grain for this one
Well now there I can help. Firstly if you Must use T-nuts .. dont pound em in. Line up the hole and put a washer on the bolt, then pull em into place. Alot easier !
BUT ... I wouldnt use T-nuts, go back to PE and pick up some knife inserts.
WAY more dependable that the Ts..
Yes, you can order em with or without a flange and sizes that can stay embedded into the wood and not go through the back. For extra security a drop of glue can go on each as well. Drawback of Ts is that sometimes a tooth or two will break off leaving it nearly impossible to take a driver back out. If PE doesnt have the right sizes for you, you can get em from www.mcmaster.com
Don, are THESE ( http://www.partsexpress.com/pe/showd...umber=081-1084 ) what you are talking about.
Ive about had it with friggin Tnuts myself.
The ones in my current box are worthless, I ended up friggin turning the driver a little bit and running screw to mount the sub.....
Ive never had Tnuts kick my azz so bad. :o
Hey did you ever figure out your curve delima for your amp rack???
I was thinking if you made the end panel and middle supports out of MDF and cut the curves into the supports you could use 1/4" masonite to make the face panel.
or you could use something like this:
http://www.vandykes.com/product/02007824/
Originally Posted by Bartak1
Or these things....http://www.partsexpress.com/pe/showd...umber=081-1092
Very similiar, but you would want the thread uinflanged ones. Try mcmaster or Ill try to find it in a bit for ya..
