04-08 Rear Seat Backrest - photos of the back side of the back rest
Old 05-19-2009, 01:13 AM
ARCuhTEK's Avatar
This thread is for anyone who is even remotely thinking about removing the rear seat backrest of a SuperCab or SuperCrew F150 (2004-2008).
There have been many threads on HOW to remove the back rest, one of which I authored, can be found here. https://www.f150online.com/forums/ar...08-my-way.html
But several people have asked me to post pics of the details of the back of the seat, since, if one is trying to remove it, the effort can be difficult. Sometimes it helps just to be able to see (ahead of time) what you cannot see before you start. So here goes:
Here is the entire backside of the back rest. Never mind the blue junk...I taped the metal straps so it would not scratch my amps. I have the straps covered much better now. The blue color on the foam, I am not sure how it got there, but it had something to do with the blue painters tape....weird that I cannot remember.
P5090308.jpg?t=1242708538
In the pic above, of particular importance to note is the metal rods extending down from the head rests. Do NOT forget them when thinking about where you will place your amps on the back wall!!!
You can also note the metal struts which flank the armrest in the center of the backrest. Those will get in the way of any equipment you might wish to mount on the rear wall as well. Here is a different view of those struts.
P5090318.jpg?t=1242709941
Here is a pic of the very sharp seat alignment fork (for lack of better terms) that slides down onto the rear seat tubular brace. After you successfully break the backrest free, and pull it away from the wall, be very careful as this lil puppy will rip the leather on your rear seat if you are not careful!
P5090311.jpg?t=1242709304
There are three plastic clips at the top of the back rest that anchor it to the rear wall. When removing the backrest, the bottom of the backrest must be kicked forward and then the backrest must go vertically upward (all in one swift motion. These clips show you why the back rest must go up as the final step before the seat is free to be taken from the truck.
P5090315.jpg?t=1242709530
The diagram I made for removing the seat shows an area where a screw driver must be inserted (if using my method) to reach the black plastic release clips holding the seat down. Here is a pic, showing the metal "tabs" through which your screw driver must pass on its way to touching the release clips.
P5090310.jpg?t=1242709689
Remember...you are looking at all these pics from the backside. When sitting on your rear seat, you will obviously have a different view point.
Hope this helps someone!
Old 05-19-2009, 01:17 AM
DARK KNIGHT08's Avatar
Thanks for the write-up, I'm sure it will help alot of people.
Old 05-19-2009, 01:22 AM
ARCuhTEK's Avatar
You are welcome. I was just going to add these to my previous thread and then it occurred to me that some people might want to have access to these photos who are not necessarily in the middle of an audio installation/build. Myh other thread is focusing on that issue. So I made a new thread, and I also updated the previous threads with links and images.
Old 05-19-2009, 10:51 AM
bigdog87's Avatar
I got the backseat off yesterday!!
Old 05-19-2009, 12:04 PM
mSaLL150's Avatar
Ah yes, the backrest of the backseat. I have fought many a battle with that bad boy. Now that I've defeated him, hes picking fights with my amplifiers though. I need to wrap those metal braces in foam or something.
Old 05-19-2009, 01:35 PM
bigdog87's Avatar
I've got to figure out if my amps will fit back there!
Old 05-19-2009, 08:56 PM
ARCuhTEK's Avatar
Anyone who wants to put amps behind the rear seat of a 2004-2008 F150 has to fight that battle. You can do it!
Old 05-19-2009, 10:42 PM
bigdog87's Avatar
yessir,
Old 05-20-2009, 12:18 AM
squirtbottle09's Avatar
Yeah its a pain to do but well worth it.
Old 06-10-2013, 07:57 PM
DaddyBean's Avatar
Thanks for the method and pics. The Haynes manual is completely, utterly, stupidly useless for this.
My $0.02 contribution, when you reach back behind the seat, you'll find a vertical plastic piece back there, maybe three inches high and maybe 3/8" in cross-section, a little curve and with sort of a hook on top. That's not the latch, but it's close - the piece you're looking for is just in front of that one, a little shorter, and a lot flatter & thinner, maybe an inch wide and 1/16" thick. Pry that thinner piece toward the back. It doesn't have to move very far to release that side, maybe a quarter inch or so.
Old 06-11-2013, 04:00 AM
code58's Avatar
=DaddyBean;4994551] The Haynes manual is completely, utterly, stupidly useless for this.
I thought it was for pretty much anything! At least that's been my experience. I would consider asking a random passerby for help before using the Haynes manual.
Old 06-17-2013, 09:55 AM
DaddyBean's Avatar
LOL, I know what you mean - but even the really bad sections can at least give you an idea what you're in for. e.g. I needed to replace something (starter?) in a Toyota Tundra, and the book said "1) Remove the intake manifold assembly (see chapter 12)."
All it says for this is something like "Release the seat-back catches (see photo)", and the photo shows a screwdriver in the proper position but literally zero detail about what needs to be done. Um, gee, thanks for the help, Mr. Haynes.
Old 05-22-2016, 06:31 PM
Dogtired1961's Avatar
Backrest removal
I used your link the schematics and instructions made my life so easy. Thank you!
Old 06-16-2019, 03:58 PM
mike younkin's Avatar
Photos won't open
Old 06-16-2019, 07:12 PM
They are displayed in the quote in post #13.
Quick Reply: 04-08 Rear Seat Backrest - photos of the back side of the back rest
