Project Survival Truck
re your "08 XL rab/6.5'" - what engine/trans/axle ratio are you running?
so far, it's one vote for 4.1, and one against. appears unanimous against the 3.73. ultimately, what i'm trying to do is get farther up the torque curve for a given RPM. that's why i'm asking for opinions of those who have gone before.
as to them being small for a survival truck, the difference is simply not enough to matter. remember, i'm going around, not through, and i've lost, with these tires, maybe half an inch of ground clearance. but, i've gained some resistance to punctures.
as i mentioned, when they do get replaced, i will upsize, and by that time i'll have made the suspension decisions, such as long travel vs payload, etc., so i'll know how big i can go.
i have no budget, but i do finally have a better job, so i've got more money coming in. i'm being thrifty, but not cheap, so that stretches out the time line.
4.10's will increase your RPM's by only 300.
4.30's= 410 rpm increase
4.56's=550 rpm increase
if you are changing rear ends, i would get a locker put in too! either a detroit trutrac or a detroit locker.
as to the RPM's, I already knew that. the problem is that i have no idea where on the torque curve that puts me. that's why i'm asking for other's real world experience.
or, the torque curve if someone has it...
Swapping from 3.55s to 3.73s generally isn't cost effective, and if you jump up to 4.10s, I'd recommend running at least a 31" tire, preferably a 33. Though all of those changes are going to impact fuel mileage.
How much highway time do you see?
the real world!
regarding costs, I don't see the contradiction you see. First of all, you're putting words in my mouth - I don't believe I said the choice is made solely - "...just because..." - on cost.
Cost is a real world constraint. if you know of a way to disregard cost in any process, please clue me in.
heck, run for president. you got my vote!
i wish....
Its an 08 F150 2wd with 4.2 V6 and 5-speed standard transmission and 3.73 gears with limited slip.
I do not agree with the idea of changing tires just because I'm changing gear ratios. I am no expert, but it seems to me you're taking with one hand and giving with the other. If 4.10 is the "correct" ratio, then why would i want to drive the effective ratio higher by going to taller tires?
the highway time is part of the daily commute. there's no real advantage, i don't think, to optimizing for the highway. I'm either commuting, or driving around the hill country property.
Hero of the Day
thank you, thank you, thank you!!!!
you are officially the hero of the day!!!
