Why doesn't my 4WD floor shifter go into low?
Old 08-01-2009, 03:27 PM
TheGreenMachine's Avatar
It goes into Hi just fine everytime no problem or sounds. When I get past N and try to shift over to Low it makes terrible racheting sounds. What is going on?
Old 08-01-2009, 09:26 PM
Hello? This mic on?
Old 08-01-2009, 10:58 PM
Brad6412's Avatar
this happened to me recently and i took the truck to the ford store and i had to replace the fork that pushes it into 4wd. it was about $375 if remember correctly. hope this help some.
Old 08-02-2009, 02:33 AM
4.2trimble's Avatar
are you putting the truck in Neutral?
to shift into 4lo the truck has to be in neutral.
and its also really bad for the Transferrcase to engage on pavement, or other high traction areas.
Old 08-02-2009, 11:55 AM
glc is offline
And stopped with your foot on the brake.
Old 08-02-2009, 04:00 PM
Thanks guys I'm not sure what is wrong but I am trying to engage it correctly with it in N and foot on brake. I use to use it and it went in fine but now uh...... no.
Old 08-02-2009, 05:27 PM
the nut holding the steering wheel needs to be replaced
it's probably the above mentioned fork
Old 08-02-2009, 07:38 PM
Brad6412's Avatar
let me look through my receipts and ill get you the price of the part and labor at the local ford dealer.
Old 08-02-2009, 07:41 PM
Brad6412's Avatar
just looked, the labor was $158.xx and the part itself was 196.xx coming to a total of 355.xx for rvrything installed. that fork is what physically pushes the TC into gear. so that most likely your problem.
Old 08-04-2009, 10:21 PM
Smile
Thanks Brad for the help and finding that for me. I will check into it.
Quick Reply: Why doesn't my 4WD floor shifter go into low?
