Regearing
Old Dec 10, 2006 | 08:17 PM
jiggle's Avatar
Regearing
I'm looking into regearing my 3.55s up to 4.88s or 5.13s. I can get new gears for the rear for around $200. The site I was looking at didn't say anything about the front end though. I have an 8.8 in the rear, so does that mean I have the same in the front? I saw a post somewhere on here that said all the fronts are 9.75 regardless of what's in the back. Is this true?
Also somebody told me that I can only fit like 4.10s on my stock carrier, yet I haven't read anything about needing a new carrier to go bigger than that. I just need a little guidance.
Old Dec 11, 2006 | 04:03 AM
bigtruck311's Avatar
you dont need a new carrier up to 4.88, after that i would need to make a phone call, all f-150 4x4 hav a 8.8 in the front regardless of the rear, it is a ifs 8.8 reversed cut gearing. you will need to do a gear change to the front and rear at the same time. also what size tire do you plan on using? 5.13 is a pretty low gear i have 38" and 4.88 got me into the correct RPM range. let me know if you need any more info
Old Dec 11, 2006 | 07:33 AM
jiggle's Avatar
I thought that 5.13s seemed pretty low but I was just refering to one of those charts that you see all over the place. I plan on running 35s and possibly 37s eventually. If I were to buy 4.88s would I just buy 2 of the same thing or are they different products? Also I have a 4.6l so I'm trying to make up the power that my engine lacks with lower gears. I have rebuilt 2 rear differentials, but I've never opened my front. It looks a little different. Is it harder or is there any major differences I should know about?
Old Dec 11, 2006 | 12:03 PM
KickinBlue4x4's Avatar
4:88's would def. be fine IMO.
Old Dec 12, 2006 | 05:20 AM
the rear uses a standard 8.8 the front uses a 8.8 IFS with reverse cut gears, what do you mean you have rebuilt rears ends before? doing a ring and pinion requires some speceal tools like a bearing press and a magnetic base dial indicator, if you dont feel comfertable doing it yourself i would find a freind who is or take it to a driveline shop. doing the front is the same as doing the rear, taking apart the axles is a little diffrent but the setup of the ring and pinion is the same. good luck
Old Dec 12, 2006 | 07:58 PM
jiggle's Avatar
I have replaced the stock open rearends with posi units in both of the trucks that I have owned. I called up Randy's Ring and Pinion, which is who I have always bought my stuff from, and he told me not to go lower than 4.56s. He also said that the front differential with IFS is a completely different setup than the rear. He told me that I should probably not attempt the front. So now I'm getting different opinions and I'm becoming more confused than I was before I asked the question.
I do feel comfortable working on a REAR diff, but I have never opened up a front so I need to know if there are any major differences. If it is just about the same then I should have no problem.
Old Dec 13, 2006 | 01:49 AM
Randys is a good source, when you put in the posi units did you check the backlash and your run pattern ( grease paint on the gears to see the setup pattern) if you set it up properly, than you should have no problem seting up a ring and pinion. and doing the ring and pinion in the front is exactly the same setup as the rear, like i said earlier if you dont feel comfortable doing in take it to a shop or find a freind, it is easy to mess up the setup of a ring and pinion, one time i spent 8 hours pulling the pinion of and ajusting the pinion depth before i got a setup pattern i was happy with, this was on a dana 60, but setup on a ring and pinion is close to the same on most axles. good luck
Old Dec 13, 2006 | 09:14 PM
jiggle's Avatar
Yeah I made sure everything was within specs on my posi. I was surprised because it really wasn't as hard as I thought it would be. Both times it took me around 2 hours to shim it out correctly and check the wear patterns. I'll have to do a little more research but so far I think I'll probably end up doing it myself.
Old Dec 17, 2006 | 09:42 AM
it really isnt that hard to do if you know what you are doing, have have done over 15 in many diffrent vehicles nver came across any problems exept with a dana 60 that we had to use a case spreader to get the carreir to fit, other than that i have never really had any problems. and with the 8.8 you dont even need to replase the carrier so setup usally goes smother, good luck
