Started my build yesterday.
  #46
Old 04-26-2009, 10:09 PM
7Rook7's Avatar
Originally Posted by Sundevil2188
Are you using an RCA pass through from the mono to the 4 channel?
no... im using 3 17 ft stinger HPM series 1 2 channel RCAs. they are directional and they are all going towards the amps. im totally befuddled here. i dont have my bass **** hooked up yet. ive been told that it cleans up a lot of noise, so im hopin that will help.
  #47
Old 04-26-2009, 10:35 PM
Low_e_Red's Avatar
Ok, theres no whine when the 500/1 isnt on. But if the amp is on and doesnt have RCA's plugged in the whine is back. Where are you unplugging the RCA's the amp or the deck?
  #48
Old 04-26-2009, 11:04 PM
7Rook7's Avatar
the amp
  #49
Old 04-27-2009, 12:27 AM
JJDH's Avatar
are they in the right input? had to ask,
, that hu has alot of rca.... low e will get u figured out.
  #50
Old 04-27-2009, 02:37 AM
Sundevil2188's Avatar
Originally Posted by 7Rook7
This is what I have figured out so far.
1) The whine is in the door speakers.
2) The whine is ONLY when I have the sub amp powered up also. Does not matter if I have the RCAs hooked up on the sub amp or not. No sub amp, there is no whine in the door speakers??????? got me confused.
I have a distro block for the ground and the power. I was going to change my grounding spot until i unhooked the 500.1 and noticed that it was only in that amp so i figured it wasn't the ground spot.
Any suggestions?
I wonder if the 500/1 is bad/has a bad ground and is backfeeding through the power wire to the distro block and to the other amp? Just throwing ideas out there...kinda stumped on that one.
  #51
Old 04-27-2009, 02:42 AM
Or are all the RCA's ran seperate from the power wire(like down opposite sides)? If not I wonder if the draw from the second amp is causing interference from the RCA's whereas one amp isnt enough to cause it?
  #52
Old 04-27-2009, 07:47 AM
7Rook7's Avatar
I kinda thought the same thing, but im definately no expert. I may have not done enough trouble shooting and be totally off on this as well. Im going to pull the amp today and put in my brand new 500.1v2 and see what happens
The rcas are down the passenger side sill and the power is down the drivers side. they only cross where the 0/1 ga is running up to the dist block and the rca to the sub is running to the amp. but i still get the noise even when those rcas arent hooked up
  #53
Old 04-27-2009, 12:51 PM
Yeah, but if the 4 channel RCA's are right next the the power wire, with the second amp on there is more draw coming through the power wire to power the second amp, which could be causing the interference.
  #54
Old 04-27-2009, 04:07 PM
JJDH's Avatar
i would guess amps internal ground is f ked up, is anything behind hu touching each other?
  #55
Old 04-28-2009, 06:43 PM
7Rook7's Avatar
OK... I think I have found the problem... I was going to take the amp out and hook up my other 500.1 to see if it was the amp. i took it off the back wall and started up my truck to see how it sounded. NO NOISE!! I attach it back to the wall and I have noise again...
Im assuming that my screws that are holding the amp to the sheet metal are causing the issue????
If that is the case, why is the same thing not happening with the 300.4? its attached the same way.... 1 inch self tappin screws... 1/4 inch masonite with carpet, sound deadening and then sheet metal
Should I redo the amp board with 1/2 inch mdf and use 1/2 inch or 3/4 inch wood screws so as not to hit the sheet metal??
When I first thought about attaching my amps on the back wall I assumed that screwing into the sheet metal would be a bad thing, but I thought that i have seen some pics of amps screwed directly to the sheet metal....
Any suggestions?? Thanks
  #56
Old 04-28-2009, 11:00 PM
mSaLL150's Avatar
I used 3/4 MDF boards and 3/4" screws so it doesn't hit the sheetmetal. I have ZERO floor noise.
  #57
Old 04-28-2009, 11:49 PM
bigchief2472000's Avatar
my amp is grounded to the floor of the cab and i mounted it on the back wall with the screws going into the metal, no issues with noise on mine.
  #58
Old 04-29-2009, 05:16 AM
Low_e_Red's Avatar
Sounds like an overlapping ground problem.
  #59
Old 04-29-2009, 08:05 AM
7Rook7's Avatar
Im not quite sure what you mean.........Could somebody elaborate?
  #60
Old 04-29-2009, 05:43 PM
JJDH's Avatar
Quick Reply: Started my build yesterday.
