Super chip Emergency. Please Help
Old May 23, 2000 | 09:29 PM
Floyd91's Avatar
Post Super chip Emergency. Please Help
I have the super chip flip chip, I tried installing it today, following the directions from this site exactly. The theft light flashes really fast and the truck will not start, with or without the chip it does the same thing. Any help is greatly appreciated.
Floyd91
Why do I do the things that I do? Because, The chicks dig it!
99.5 White lightning
#2349 Born on 6/14/99
Clear Corners
Clear Tail lights
APC Ultra White headlights
PIAA Super White Driving lights
PSP Filter Kit
Superchip Flip Chip
BellTech 3/4 drop
Razo carbon Race Pedals
Racing Trendz!
Old May 23, 2000 | 09:34 PM
Lightningquick's Avatar
Post
Take out the computer and take a small screw driver and shave off **ALL** the silicone off the computer terminals.THEN use the little pad.90% of problems lead to bad installation.Dont worry,The other 10% of problems I have already dealt with!Ive had all the bad chips in my truck,Their cant be any more bad chips out there Ive already had them all
[This message has been edited by Lightningquick (edited 05-23-2000).]
Old May 23, 2000 | 09:57 PM
mswaim's Avatar
Post
I have to agree. When I installed their chip in my cobra, I had a similar experience. I was able to trace it back to my failure to completely clean off the mating terminals. Of course, I was in a hurry to fire the beast up, and since this was the last step of the install, I cheated a bit.........had to do it all over again, what a pain. Good Luck !
Old May 23, 2000 | 09:58 PM
Floyd91's Avatar
Post
But with out the chip the theft light still flashes and no start. I took a small screwdriver to the terminals, I took a magnifying glass to it and it is clean. Its bare. This is really frustrating as I have nothing else to drive.
Old May 23, 2000 | 11:16 PM
4D THNDR's Avatar
Exclamation
Harvey: Check to make sure you didn't bend one of the pins on the computer connection harness that the 10mm bolt holds on. Also make sure the chip didn't get wedged loose from the bracket that holds the factory computer in place. There is a lip that gets between the chip and box sometimes. Do ALL work with the battery disconnected. I don't have access to your e-mail or phone as I'm at work but if I can help call me, I'm here until 05:30 EDT ----------
Red '00 Lightning,
Adopted 4/19/00,
PSP Filter,
Sound effects provided by Flowmaster,
Track time pending...
[This message has been edited by 4D THNDR (edited 05-23-2000).]
[This message has been edited by 4D THNDR (edited 05-24-2000).]
Old May 23, 2000 | 11:36 PM
Floyd91's Avatar
Post
all work has been done with the batter disconnected. All pins are in perfect working order. I don't understand why this is doing whatever it is doing, I put everything back to stock and still the same thing, also noticed that the overdrive light is on now too.
Old May 23, 2000 | 11:41 PM
4D THNDR's Avatar
Question
When you remove the chip completely it still doesn't start?
Old May 23, 2000 | 11:44 PM
Floyd91's Avatar
Post
yeah. Lights still flash and everything. Like it did with the chip.
Old May 24, 2000 | 12:01 AM
ZorPrime's Avatar
Exclamation
same thing happened to me.MAKE SURE that the harness is secured to the pcm securely.It frieked me out when i couldnt get mine to start but that was my problem.
99.5 Lightning(white)
Best 1/4 mile:13.89 @ 98.1 mph, 60':2.02(stock)
ARE LSII Tonneau w/wing
Alpine Stereo System(500 Watts)
clear turn lenses/clear tail lenses(on order)
Phantom Boost Guage
AirRaid Filter Kit
PSP Chip(installed)
Ford Racing 3.73 Gears(installed)
Belltech 2" Drop Shackles
Old May 24, 2000 | 12:05 AM
4D THNDR's Avatar
Post
Yeah, snug down the harness but don't stand on it. You have to pull all those pins in so there is resistance for quite a few turns.
Old May 24, 2000 | 12:35 AM
Floyd91's Avatar
Post
so Turn the 10 mm bolt in for a while? Ok I will go try that, I kinda only have this one vehicle and kinda need it to run :P
Old May 24, 2000 | 12:38 AM
4D THNDR's Avatar
Cool
Understood.
Red '00 Lightning,
Adopted 4/19/00,
PSP Filter,
Old May 24, 2000 | 12:56 AM
Floyd91's Avatar
Post
still nothing, pcm harness did need a little snugging though.....ugh why oh why.
Old May 24, 2000 | 12:58 AM
4D THNDR's Avatar
Post
You just call?
Old May 24, 2000 | 12:59 AM
Floyd91's Avatar
Post
No I did not. hmm I wonder what mike troyers home number is :P
