Super chip Emergency. Please Help
Old May 24, 2000 | 03:57 AM
  #61
A Train's Avatar
Post
the flywheel on my press is massive. the motor is about as big as my truck. if only i could put it on wheels....it would haul ***.
Old May 24, 2000 | 04:00 AM
  #62
4D THNDR's Avatar
Thumbs up
I'm sure it's also powered by electricity. Just the thing I like to see .
Old May 24, 2000 | 04:14 AM
  #63
A Train's Avatar
Post
especially with todays gas prices, i would need one helluva solar panel!
Old May 24, 2000 | 05:10 AM
  #64
all4chem's Avatar
Post
ooops
[This message has been edited by all4chem (edited 05-24-2000).]
Old May 24, 2000 | 10:46 AM
  #65
Floyd91's Avatar
Post
Well it still does not run, I left the battery disconnected all night on it and the dash is still lit up like a christmas tree. The fuel pump reset I believe is fine, it looked like a pop up switch, and it was not popped up.
Old May 24, 2000 | 03:16 PM
  #66
98_SVT_COBRA's Avatar
Post
I have heard of the chips corrupting the PCM's programing. If that happend you'll need to have it reflashed. Have you called Mike T.? He may be able to help. Would it be possible to install the board in the PCM upside down? Good luck.
Old May 24, 2000 | 03:37 PM
  #67
Floyd91's Avatar
Post
The chip looks like it can be plugged in either way, but will only fit the right way, while the computer is mounted. It would only look right one way also
Old May 24, 2000 | 03:40 PM
  #68
Pacecar18's Avatar
Post
How much gas did you have when you parked the truck? Just/Kidding
Assuming common sense such as gas in the tank, Shifter in Park, etc.
I heard that you should disconnect the battery and then turn on the headlights to drain the rest of the power out of the truck. Then reconnect it and try again.
Also try your spare key to see if the key is the problem.
Does sound like a fuel issue since the motor cranks. There have been problems with fuel pump connector breaking and not giving any fuel pressure.
If all else fails call your dealership and tell them your truck won't start.
[This message has been edited by Pacecar18 (edited 05-24-2000).]
Old May 24, 2000 | 06:16 PM
  #69
Floyd91's Avatar
Post
Fuel tank is 3/4 full. The fuel reset switch is not tripped. There is no gas or leaking fluids anywheres. No bent pins no nothing. But what I did find was a weird clicking noise when I connected the negative terminal on the battery. It happened every time I did it. I traced it to the fuse box under the hood by the air cleaner, where I found a 15 amp fuse was blown. I am praying that this is the problem as everything else seems to be in working order. Would? Could? this be the problem? Someone please say yes..... I would like to think you all for your help and patience. I will try the fuse when I get off of work...cough cough feeling a little sick, I can't stand for my baby to be broken.
Old May 24, 2000 | 07:48 PM
  #70
Floyd91's Avatar
Unhappy
That did not work either. The fuse did restart the fuel pump, I believe. But the theft light is still flashing, and no start. engine just cranks and cranks.
Old May 24, 2000 | 10:48 PM
  #71
ZorPrime's Avatar
Exclamation
Mine did the same thing....and it was that PCM harness.Here is exactly what i did.
Installed the chip,tightened harness
Try to turn engine over,nothing happens
Tighten PCM harness...try to turn engine over again....engine cranks and cranks never turns over.
removed chip,tightned harness more ,try to turn the engine over.truck starts.
turn truck off,remove neg battery terminal,replace chip
attempt to start truck again w/chip
PRESTO!!!!
It starts.
It took me a little while to get it,but i finally got it going.I was sweating bullets when i couldnt get mine started.
99.5 Lightning(white)
Best 1/4 mile:13.89 @ 98.1 mph, 60':2.02(stock)
ARE LSII Tonneau w/wing
Alpine Stereo System(500 Watts)
clear turn lenses/clear tail lenses(on order)
Phantom Boost Guage
AirRaid Filter Kit
PSP Chip(installed)
Ford Racing 3.73 Gears(installed)
Belltech 2" Drop Shackles
Old May 24, 2000 | 11:40 PM
  #72
4D THNDR's Avatar
Lightbulb
http://www.mustangworld.com/ourpics/fcar/dtcodes.htm
Red '00 Lightning,
Adopted 4/19/00,
PSP Filter,
Sound effects provided by Flowmaster,
Track time pending...
Old May 25, 2000 | 01:28 AM
  #73
Floyd91's Avatar
Post
Ive cranked the harness untill I thought it would strip. It was very very tight. I don't think It would get tighter. Oh well I will try again.
Mike~ Sorry I missed your calls, I was with my girlfriend, and well.. yeah
Old May 25, 2000 | 01:49 AM
  #74
DuckHntr's Avatar
Talking
I sounds as though you have a problem with the "Passive Anti-Theft" ignition key thing. They can get corrupt and when you crank the engine over, it won't start (just like being out of gas).
  #75
4D THNDR's Avatar
Wink
Understood.
Red '00 Lightning,
Adopted 4/19/00,
PSP Filter,
