Problem with headlights
Old Oct 24, 2012 | 09:06 PM
STX_HILL's Avatar
Hello this is my first post, i drive a 2012 ford f150 STX 4x4. i was trying to install bi xenon hid's and the passenger hid came on for a second and then went out. i trying checking all the connections and tightened everything then nothing would come on. it started to get dark so i put the old headlights back in and the only light that would work is the driver side low beam, not the high beam, just low. no fog lights either. anything? or should i just bring it to ford?
Old Oct 24, 2012 | 09:55 PM
powerz69's Avatar
Blown fuses, melted wires?
Old Oct 24, 2012 | 09:58 PM
STX_HILL's Avatar
i checked the wires from what i could get at. as far as the fuses i couldnt find what fuses to look at in the box.
Old Oct 24, 2012 | 10:10 PM
STX_HILL's Avatar
i went out to try the lights again and not no lights come on, i have no idea. should i just bring it to the dealership?
Old Oct 24, 2012 | 11:14 PM
powerz69's Avatar
What hind of HID kit did you install? Does it have a relay harness?
I'm guessing you blew your headlamp, fog light fuses.
Does your truck still start/run? Does your horn, or interior lights work?
Old Oct 24, 2012 | 11:20 PM
STX_HILL's Avatar
i used a xentec bi xenon kit. it starts up and drives, interior lights work. horn works. im thinking im just gonna go to the dealership and have them fix it..the truck is 5 days old!
Old Oct 24, 2012 | 11:26 PM
powerz69's Avatar
Just pull the fuse box cover off and it should say on the back of the cover or where the fuses go the names. Look for headlights, high beam, low beam, fogs when you find one or all the names pull the fuse and check it.
Old Oct 25, 2012 | 02:05 AM
Raptor05121's Avatar
Check the fuses or take it to the dealership and send back that crappy *** $35 kit and stick with halogens. You're going to fry a computer if you arent careful.
Old Oct 25, 2012 | 12:20 PM
SSCULLY's Avatar
Open your owners manual and check the section on fuses, to find the 2 fuses that might be blown.
1. passenger side low beam : cab fuse #16.
2. high beam fuse ( both ) cab fuse panel # 39
The fog lamps, Not too sure is going on there, check the steering wheel control module fuses and the fog lamp fuse.
I hope this kit used a relay to power the HIDs, if not you might have a FET turned off.
did you do any splicing to the factory wires, or was it a bulb connector that plugged into a headlamp connector to trigger the HID system ?
BTW : Unless you went up by the PCM or into the cab of the truck, you are not going to "fry a computer."
Old Oct 25, 2012 | 02:20 PM
STX_HILL's Avatar
Took it to the dealership, it was in fact just some blown fuses. Thanks guys
