Retrofit
Old Jun 24, 2011 | 05:47 PM
  #61
2000FORDMAN's Avatar
This is how they came:
Not sure if I have to trim the metal tabs down or what? When I called they had just closed until monday
Old Jun 24, 2011 | 07:12 PM
  #62
Ok another IMPORTANT question. On that wire harness, it has that big blue plug. Does that plug in on the passenger side or the drivers side? I have one blue plug on the drivers and one on the passenger. This is needed ASAP please.
Old Jun 24, 2011 | 11:52 PM
  #63
powerz69's Avatar
If your talking about where the factory bulb plugs in then it doesn't matter which side. I think i used the passenger side factory bulb plug to the harness just because it was closer.
Old Jun 25, 2011 | 01:54 AM
  #64
Raptor05121's Avatar
WTF I've never seen that! I'd definitely call them on monday!
hits it on the head
Old Jun 25, 2011 | 09:03 AM
  #65
Thanks for the info guys. Im gonna cut the tabs off the high beam wires and put the tabs they provided me on, those are the right ones. Gonna get started here in a little bit.
Old Jun 25, 2011 | 11:15 AM
  #66
Have fun and TAKE YOUR TIME!!!
Old Jun 25, 2011 | 11:25 AM
  #67
Try to. I have all weekend. Probably gonna get it all wired and mounted and aimed today. Gonna seal everything up tomorrow.
Old Jun 25, 2011 | 08:36 PM
  #68
Well I got most of it done. I got the harness in and the projectors bolted in. Its aimed about where it should be. The shrouds are a MAJOR PITA. I have to notch them on the top and bottom so they will fit inside the housing. Just have to cut the shrouds, splice in the CCFL's wire up the high beams, and seal them up. Gonna do that tomorrow.
Old Jun 26, 2011 | 10:18 AM
  #69
Man the shrouds are the hardest part of this whole project. Almost got one shroud to fit. Hopefully the next one goes easy.
Old Jun 26, 2011 | 12:18 PM
  #70
Yeah same for me.
Old Jun 26, 2011 | 04:30 PM
  #71
98% done. Everything is sealed and installed. Just gotta wire the high beams and call TRS tomorrow and find out how to wire those light rings.
Old Jun 26, 2011 | 05:46 PM
  #72
Alright guys all done:
All I have left to do is call and figure how to wire up the CCFL's and if it matters which wires go into which plugs for the high beams.
I will try to get some night pics tonight.
Old Jun 26, 2011 | 06:00 PM
  #73
DanielWalker10's Avatar
the ccfls should just be a (+) & (-) 12v source. most tap into parking lights or run a switch..
Old Jun 26, 2011 | 06:25 PM
  #74
very nice!!!!!
high beams are a simple +/- system. Find out which is which and wire it up. Same for the CCFLs. I'll add you to the list
Old Jun 26, 2011 | 06:54 PM
  #75
So does the CCFL's have a ground wire? I spliced them to the running lights and ran one wire to a ground and they didn't work. That's what I was told to do. Also for the high beams, both wires are exactly the same. Does it matter which wire goes to which of the 2 slots on one high beam plug?
