Retrofit
I installed the harness and mounted the ballasts before beginning any work so I could test them out.
You can use a modified computer power supply to ignite a ballast if you want to play with them in-house
If you are using the Mini H1 you shouldnt have to do any cutting, maybe just a small insert with the dremel for the high beam wire.
Im getting the FX-Rs.
You are SOO lucky. Right now I am going through my drawer which has my Lowes receipt and the little baggies that held the screws
20x 4mm Split Lock Washers (two 10x bags)
20x Class 8 M4-.70 Hex Nuts (two 10x bags)
8x Class 8.8 M4-.70x20 Hex Cap screws (two 4x bags)
20x 4mm flat washer (two 10x bags)
All of these come in those little dime-sized Hillman bags at Lowes. Dont forget to get a single 2.8oz tube of GE Clear Waterproof Silicone.
