F150Online's Retrofit Members
Old Aug 12, 2011 | 02:44 PM
  #61
Scott011422's Avatar
Does anyone have 3000k in their fogs? Finally getting around to doing my fog conversion, But I can't make up my mind between matching my heads or running 3000k's. My no 1 problem is I can't get 3000k's in 50 watt. So it would be 3000k at 35 watt or 5000k at 50 watt..........
Old Aug 12, 2011 | 03:02 PM
  #62
mSaLL150's Avatar
Running 50w in the fogs is gonna be a problem, too hot. You can't fit a large enough projector in the fogs to run 50w.
I have 5000k in my fogs right now to match the headlights but once duck season comes around I will be switching to 3000k for fowl weather performance.
Old Aug 12, 2011 | 03:03 PM
  #63
Personally it would look better if they matched the heads.....but if you want the yellow euro look that's cool also.....
Old Aug 12, 2011 | 05:00 PM
  #64
No, don't like the euro look, But I do like the look of the road through the Illinois fog and snow!
Old Aug 12, 2011 | 05:50 PM
  #65
Agreed....
Old Aug 12, 2011 | 05:55 PM
  #66
blackknight87's Avatar
Yea i was never a fan of yellow fogs. always looked weird to me.
Old Aug 12, 2011 | 06:01 PM
  #67
Thanks, Ordered the Mini D2S instead with the long lead 35 watt and the 5000k. I'll switch over to 3000 when winter is closer.
Old Aug 12, 2011 | 08:57 PM
  #68
TJL442's Avatar
That is what I installed in my HID fogs and be prepared to do alot of grinding. I may have some pics of my lights after the grinding to get them to fit if your interested. I think that the Mini H1 is a better better fit as if I recall they are a little shorter than the D2S. The light output is amazing thogh.
Tim
Old Aug 12, 2011 | 10:49 PM
  #69
Sure! Can never have too many ideas. I'm just hopeing I didn't shoot myself in the foot not going with the FX-R's
Old Aug 12, 2011 | 10:58 PM
  #70
Raptor05121's Avatar
FX-Rs have a slightly wider output and better high beam. The only reason one should NOT use FX-Rs is when space restraints are a issue (just my opinion).
Old Aug 12, 2011 | 11:03 PM
  #71
Thats why I went with the mini's, Its just, I bet I could have found SOME way of fitting them in there...
Old Aug 13, 2011 | 10:30 PM
  #72
TJL442's Avatar
Before grinding, top is actually the left side.
View of the top part of projector after grinding, drilled and tapped new holes to mount the plastic.
Tim
Old Aug 14, 2011 | 02:29 AM
  #73
mSaLL150's Avatar
I went the other direction with my fogs...instead of grinding the projectors, i cut the crap out of the housing. Tons of work, probably not worth it. Purely cosmetic. The fogs add extra lumens and the quad high beams are ridiculous...but next time I am doing the LS460 bixenon in the headlights with OEM bulbs and leaving the fogs Halogen.
Old Aug 14, 2011 | 12:29 PM
  #74
Yeah once I get a new truck or car, I'm getting some LS460s with some CBI bulbs.
Old Aug 14, 2011 | 03:35 PM
  #75
mSaLL150's Avatar
Yeah I will either go with the CBIs or the Phillips Ultinons. This setup here (LS460 w/ Ultinons) is just pure sex:
http://www.hidplanet.com/forums/show...=ls460+ultinon
