Wiring Harness for Audiophile
Old Feb 16, 2005 | 01:28 PM
  #31
BINK360's Avatar
Angry
I HAVE BOTH OF THE WIRING HARNESS NEEDED TO HOOK UP THE SUB TO THE HU. ONLY PROBLEM IS ALL OF THE WIRES ARE BLACK AND THERE IS NO WAY TO KNOW WHICH WIRES CONNECT TO EACH OTHER. DOES ANYBODY KNOW WHICH WIRES GO TO WHICH PINS? I TOOK THE HARNESS TO DIFFERENT AUDIO SHOPS AND NO ONE COULD INSTALL IT DO TO FACT THAT THERE ARE NO COLOR CODE ON THE WIRES. CAN ANYONE HELP ME?
Old Feb 16, 2005 | 01:39 PM
  #32
FordNoobie's Avatar
You have to use the pin numbers that are on the wiring diagram. Try this:
Pin 3 HU -> Pin 9 Sub
Pin 1 HU -> Pin 7 Sub (Should be shielded)
Pin 2 HU -> Pin 8 Sub (Should be shielded)
Pin 4 HU -> Pin 1 Sub (Shield)
Hot at all times +12V -> Pins 5 & 6 Sub
Ground -> Pins 2 & 3 Sub
I can't believe any audio shop couldn't figure that out. That is a very basic wiring diagram.
FordNoobie
Old Feb 16, 2005 | 01:55 PM
  #33
BINK360's Avatar
Talking
THANKS FORDNOOBIE AGAIN. I WILL TAKE THIS INFO TO THEM AND SEE IF THEY CAN MAKE IT WORK NOW. I AM USING THE DIAGRAM THAT WAS POSTED IN THIS FORUM. CROSS MY FINGERS
Old Feb 16, 2005 | 02:15 PM
  #34
BINK360's Avatar
Question
FORDNOOBIE, THANKS FOR ALL OF YOUR HELP. I ONLY HAVE ONE MORE QUESTION FOR YOU. WHERE ARE THE NUMBERS AT? ON THE HU AND AMP OR WIRING HARNESS? I STOPED BY THE MADE A COPY OF THE DIAGRAM THAT HAS BEEN POSTED AND I SEE THE NUMBERS ON IT. JUST DONT KNOW WHAT WHERE THEY ARE ON THE HARNESS?
Old Feb 16, 2005 | 05:47 PM
  #35
FordNoobie's Avatar
The pin numbers for the HU harness on on the harness next to each pin connection - they are very small. I couldn't find any pin numbers on the sub harness, but they are labelled inside the sub connector (the connector on the amp) - again, they are very small.
FordNoobie
Old Feb 17, 2005 | 06:35 AM
  #36
BINK360's Avatar
Lightbulb
I SEE THE NUMBERS, THANKS FOR THE HELP. I AM GOING TO PICK UP THE SHIELD TODAY ON MY LUNCH BREAK AND RUN ALL OF THE WIRES TONIGHT.
Old Feb 17, 2005 | 10:48 AM
  #37
axe124's Avatar
bink360,
What is the shield that you need. I am in the same position as you and almost have all of my audiophile parts?
axe124
Old Feb 17, 2005 | 01:23 PM
  #38
BINK360's Avatar
Smile
AXE124, THE SHIELD IS MADE OF COPPER AND LOOKS LIKE A CHINESE FINGER PUZZEL. IT HAS A WIRE THAT RUNS THE LENGTH OF IT. LOOKING AT THE DIAGRAM THAT WAS POSTED YOU WOULD RUN WIRE'S 1 AND 2 THROUGH THE SHEILD TO 7 AND 8 PIN ON THE AMP HARNESS. YOU WOULD THEN SOLDER THE WIRE FOR THE
9 PIN TO THE WIRE THAT RUNS THE LENGTH OF THE SHIELD AT ONE END AND THE 3 WIRE ON THE HARNESS THAT PLUGS INTO THE HU AT THE OTHER END OF SHIELD. WHEN DONE PROPERLY THE SHIELD WILL BLOCK OUT OTHER ELECTRICAL INTERFERENCE LIKE ENGINE NOISE. I WAS UNABLE TO FIND ANYONE WHO COULD SUPPLY ONE. I AM JUST GOING TO RUN THE POWER WIRE DOWN THE PASSENGER SIDE OF THE TRUCK SO IT WILL NOT INTERFER WITH THE SIGNAL.
Old Feb 17, 2005 | 09:12 PM
  #39
ChrisoFX4's Avatar
Hi, I know there is a lot of information on this board about hooking up the sub/amp to the audiophile. Hopefully 2 basic questions. First, I have a 2004 FX4 with 1 cd radio. I have purchased the factory sub/amp and will install it as the factory would have. I have also bought a 6cd audiophile factory radio. Can I use the wiring that is currently in my truck if I can find the sub/amp wire that will run from the radio to the sub/amp? Can I use this harness to do this: https://www.f150online.com/forums/li....installer.com ? Or does the audiophile take special wiring all around?
Thanks, Chris
Old Feb 18, 2005 | 06:59 AM
  #40
BINK360's Avatar
Talking
I HAVE MY SYSTEM HOOKED UP AND IT WORKS GREAT! YES CHRISOFX4 YOU CAN USE THE HARNESS THAT IS ALREADY THERE FOR THE DOOR SPEAKERS, BUT YOU MUST MAKE THE SUB AMP WIRING HARNESS. I USED THE FORD PART#'S AND WIRING DIAGRAM THAT FORDNOOBIE POSTED.
Old Feb 18, 2005 | 10:31 PM
  #41
acticus's Avatar
you could just tap in to the plug using wire taps.. they work well... i used them and my sub is working with out any issues.
Old Feb 19, 2005 | 05:13 PM
  #42
woodall01's Avatar
Info for Chris
Chris,
You will need to create your own wiring from the two wiring harness listed in this posting. I know that Fordnoobie has done it. I am waiting for part which will be in Tuesday. .
Bill
Old Feb 25, 2005 | 11:24 PM
  #43
ChrisoFX4's Avatar
I pulled my radio out tonight and low and behold the subamp wire was clipped to the firewall by a holder for the radio. Does this mean that they have already run the wire for the factory subamp and it is under the rear seat somewhere? Also does anyone know the tool/socket to take out the back seat if that is the case to get to the wire, or do I even need to do that.
I am assuming they run the wire from the passengers side, is that correct?
Thank you for any help you can offer.
Update, I could not find the subamp end to the wire, I pulled out part of theback rug and looked under the rug on both the passenger side and the drivers side but no luck. Has anyone found it in a different location?
Thanks for any help you can offer.
Old Feb 27, 2005 | 03:15 PM
  #44
woodall01's Avatar
Sub Clip
Was is a male or female connector?
Old Feb 28, 2005 | 09:49 AM
  #45
BINK360's Avatar
Exclamation
chrisofx4, the wire that you found may be for the dvd player and not for the sub. The sub plug for the deck only has 4 wires coming out of it. you may need to purchase the two wiring harness.
