Wiring Harness for Audiophile
As soon as I figure out how to post an image, I'll put it on the forum. Any help on this item would be appreciated.
My local dealer ordered connectors that he thought might work and they are correct! The Ford part numbers for the Audiophile connectors are as follows:
3U2Z-14S411-DLA: Connector w/ leads that plugs into head unit
3U2Z-14S411-CAAA: Connector w/ leads that plugs into sub/amp
I should have the system working this weekend.
FordNoobie
FordNoobie
WISH I HAD KNOWN THAT I NEEDED TWO HARNESS. I WILL HAVE THE OTHER HALF MONDAY. SO FAR THE HARDEST PART OF INSTALLING THE AUDIOPHILE SYSTEM IS THE REAR DOOR SPEAKERS (YOU HAVE TO REMOVE THE COMPLETE INSIDE PANNEL)
THANKS FORDNOOBIE FOR THE OTHER PART# I NEED TO COMPLETE MY SUB HARNESS. ALSO YOU HAVE THE PART# DISCRIPTION REVERSED IN YOUR LAST POST. LET ME KNOW HOW IT WORKS OUT.
Fordnoobie,
you are correct, I called the dealer today and verifed the numbers. Now, once I get these connectors, if I take it to an audio place with this diagram...should they be able to hook me up?
axe124
axe124
BTW, do you think you can inlarge the picture a little?
FYI, I made a harness today and hooked everything up. It worked like a champ and I am satisfied with the outcome. I wasn't looking for anything that would rattle the windows, but that sub can really rock if you want it to and I was impressed with the sound quality coming from a factory system.
FordNoobie
Photo.
If possible, could you e-mail it to my roaddoc6127@hotmail.com. JPG don't blow up to well. btw; Cool that you got your sub hooked up. I can't wait to finish mine. Also how much did those wiring harness set you back?
Thanks,
Bill
Thanks,
Bill
GOOD JOB FORDNOOBIE. I HAVE A QUESTION? MY PIGTAIL WILL NOT FIT THE HU OR AMP. MY BAG THAT IT CAME IN HAS PART#
CU2Z-14S411-CAA NOT 3 AAA'S AT THE END OF IT LIKE IN YOUR DISCRIPTION. THE BAG ALSO HAS PART# WPT-404 DO YOU REMEMBER, OR STILL HAVE THE BAG, IF YOURS WAS THE SAME?
THANKS FOR ANY HELP
THANKS FOR ANY HELP
FORDNOOBIE, I HAVE THE HARNESS, I HAVE A COPY OF THE WIRING DIAGRAM, BUT IT LOOKS LIKE FRENCH TO ME. ANY IDEA ON HOW TO MAKE SURE I CONNECT THE RIGHT WIRES TO EACH. OTHER. YOU CAN E-MAIL ME AT BINK360@EXCITE.COM. THANKS FOR ANY HELP.
