Wiring Harness for Audiophile
I NEED THE PART # FOR THE AUDIOPHILE WIRING HARNESS AS WELL AND IF ANY ONE COULD PROVIDE A PIC OR DISCRIPTION AS TO WHERE THE HARNESS IS UNDER THE REAR SEAT OF THE 2004
SUPERCREW. THANKS
SUPERCREW. THANKS
harnass
i gave my audiophile amp to my friend w/ same truck but he dint have audiophile ,so he called his brother in law whom sells fords and he couldent get him a plug for it they told him that the radio has diff plugs and that cabling is done from factory
Not me - mine is due in on Wednesday along with an amp installation kit from installer.com. I don't know when I'll get to do the install but I can post results if anyone is interested. FYI, I did ask if you could just buy the sub-out plug separately - the answer was no.
Good info!
I send an e-mail to a web site called Oemfordparts.com, he told me the part number is 3U2Z-14S411-CAAA, it to plug in to the factory subwoofer. He told me the part in around 26.00!
THANKS FOR THE HELP WOODALLO1, I HAVE ORDERED THE HARNESS TODAY AND HAVE THE AUDIOPHILE SUB, DOOR SPEAKERS WITH TWEETERS AND HU ON THE WAY TO MY HOUSE. WITH LUCK I WILL NOT RUN INTO ANY MORE PROBLEMS AND WILL LET EVERYBODY KNOW HOW TO INSTALL WITH PART#S FOR THE WHOLE SYSTEM WHEN I AM DONE.
OK, now I'm even more confused. I have purchased Audiophile radio, and sub/amp. Need to install, I do not have the wire there already. Which part or connectors do I need...
1. 71-5520-1
2. 70-5520
3. 14S411-CAAA
Lately I have seen all of these listed. ANy help would be appreciated.
axe124
1. 71-5520-1
2. 70-5520
3. 14S411-CAAA
axe124
axe124,
You don't need 70-5520. This connector is required if you are going to connect an aftermarket head unit to the stock wiring harness.
I, like you, am anxious to see if the 3U2Z-14S411-CAAA connector is the correct connector for the sub. If so, one could purchase the 71-5520-1 and 3U2Z-14S411-CAAA connectors and make their own wiring harness.
FordNoobie
FordNoobie
