Old Oct 9, 2015 | 10:18 AM
  #99466
Old Oct 9, 2015 | 12:43 PM
  #99467
glad to see Jim posting again after your PW issue
Old Oct 9, 2015 | 12:48 PM
  #99468
Old Oct 9, 2015 | 12:54 PM
  #99469
BeeeDoo BeeeDoo BeeeDoo
Old Oct 9, 2015 | 04:00 PM
  #99470
Pretty neat
View this post on Instagram
  #99471
Pretty neat
Old Oct 9, 2015 | 07:16 PM
  #99472
06F150STX's Avatar
Old Oct 9, 2015 | 10:19 PM
  #99473
Question Fella's
Will going from a 18" wheel to a 20" wheel throw off my speedo? I have never screwed with wheels so i honestly don't know.
Current Tires are 275/65/18.
New Wheel/Tires are 275/55/20 (2015 Stock Wheels and Tires)
Also will the difference in 18's and 20's be noticeable with my fuel mileage?
Old Oct 9, 2015 | 10:20 PM
  #99474
Question Fella's
Old Oct 9, 2015 | 10:36 PM
  #99475
Question Fella's
The diameter of those two tire sizes is virtually identical so there should be no impact on the speedometer or odometer. The impact on mileage between the two would likely only come from any difference in weight between the two packages -- my suspicion is that the difference is probably minimal.
Old Oct 9, 2015 | 11:24 PM
  #99476
The size if the wheels don't affect the speedo, it's the height of the tire. Or actually the diameter.
Old Oct 10, 2015 | 02:27 AM
  #99477
efuehrin's Avatar
holy crap. Bluejay and Patman are still here?
Old Oct 10, 2015 | 06:38 AM
  #99478
Old Oct 10, 2015 | 07:01 AM
  #99479
Question Fella's
On paper the 18" is actually .25"-.35" larger but when on vehicle it's the same diameter as the 20" due to the tires being loaded and sidewall flex....
Depending on the wheel composition plus the tire the 18" is actually lighter than the 20" and takes less energy to start and stop its inertial force....so you may see a slight drop in mpgs with the 20"....
The other factor one needs to compare also is the rolling resistance of the tire too....this varies greatly between mfgs
Old Oct 10, 2015 | 07:20 AM
  #99480
Working on another 80 hour work week....cha ching
